Thread started 09 Oct 2010 (Saturday) 11:45
Shaking!
litratista
Oct 09, 2010 11:45 |  #1
I have neurological essential tremors since I was a kid but didn't bother me at all. I'm in the medical profession and poking patients is a breeze to me even if my hands look like a seismograph when I'm holding a needle. It started bothering me when my love for photography is getting really blurry one shot at a time. mono/tripods are the best help I can get but its inevitable that I have to shoot with my hands too most of the time. I have to take a deep breath and pretty much concentrate on my shots all the time. Any of you like me here please do tell and share any piece of advice. I like bokeh but not on the whole image :lol:
5D Mark III, 5D mark II, EF 50mm f/1.2L USM, EF 70-200mm f/2.8L IS II USM, Tokina 11-16mm F2.8, EF 24mm-105mm f/4.0L IS USM
Snydremark
my very own Lightrules moment
Gallery: 66 photos
Oct 09, 2010 12:09 |  #2
I have a bit of the same problem; the only things I can recommend are get your IS lenses, which you seem to mostly have anyway, and work on your stance/grip while shooting.
As you've already mentioned, watch your breathing; also, keep your elbows tucked as much as you can, stand at an angle to your subject and use your torso as a brace point. It's similar to firing a rifle, if you've ever done that. I'm not great at describing it in words, but hope that's useful :|
Jill-of-all-Trades
far from having everything figured out!
Gallery: 120 photos
Oct 09, 2010 12:21 |  #3
I am headed for the same fate :( Dad and Grandma both have/had essential tremors. Dad more-so than Grandma. My brother and I are already starting to see it. (late 20's) So far we are only experiencing it when stressed, physically tired, or unwell. Has not affected my photography other than a few random occasions. Hopefully by the time it becomes an issue there will have been medical and technological advances that will help.
Melody
Illumined
"i love you guys"
Oct 09, 2010 17:28 as a reply to  @ Jill-of-all-Trades's post |  #4
I want to start off by saying I am not soliciting anything when I say this, but I am merely sharing my experiences as I too, have had essential tremors since birth.
A non-addictive alternative to benzodiazapines such as Klonopin (which I use as needed rather than ED [every day] based on the likelihood of habit development using such a dosing protocol) would be beta-blockers. They are cheap and dosing is very flexible.
Propanolol is the generic version of Inderol (which I use at 80mg ED) and has helped significantly in my ability to handhold a balanced kit. If the kit is unbalanced (e.g. lens heavier than the body) then even if you didn't suffer from tremors, you'd still be prone to unwanted shake or shift.
Beta-blockers have helped me tremendously as I couldn't recommend them enough. The alleviation of physical symptoms has even actually helped me put social anxiety at bay without being dependent on benzodiazapines!
I suggest you consult your doctor or practicioner to see if beta-blockers are right for you (which is highly likely seeing as there aren't any detrimental sides from the use of them).
Ravi J.H. | Make an experience out of it - focus and expose manually.
Sony RX1 | Sony FDA-EVM1K (EVF) | Nikomat 11" cloth-locking cable release | Previous Gear
BucketMan
Oct 10, 2010 08:58 |  #5
Luminodio wrote in post #11065240 (external link)
Solid advice. However low heart rate, decreased peripheral circulation and sexual side affects could be detrimental enough to deter some people from considering this as a treatment, decreased HR being the most serious. Of course your MD will know you well enough to consider this and then of course start you on an appropriate dosage based on his/her findings if you decide this is the route you want to take.
Best of luck.
| 70D | 70-200LII | 580EXIIhttps://photography-on-the.net/forum/%3Ca%20h​ref=
litratista
Oct 10, 2010 10:50 |  #6
Unfortunately neurology is one of the hardest specialty in medicine and no one succeded today so far on what to do. Usually Benzo's, like what luminodio was saying, are one of benzodiazepines that can be used as anticonvulsants but of course its also well known as a cns depressant. Beta blockers though are not usually use for tremors, usually the desired effect for lopressors (beta blockers) is to treat tachycardia (heart rate above 100), which will in turn bring your blood pressure down also. From what I can tell, luminodio's beta blocker works with him very well even as cocktail with a benzo is either you have hypertension with cardiac anomalies plus the benzo that relaxes the neuropathies. Another thing is beta blockers will cause depression, so if you have a hyperactive body it will help mellow it down. Just in case you are using ace inhibitors, calcium channel blockers, nitrites, benzo's, barbs, be cautious! Hope this help with all my shaking shutter bug friends. And I strongly agree with bucketman, its best to consult your doctor!
tonylong
...winded
Gallery: 60 photos
Oct 10, 2010 11:14 |  #7
Aside from the medical advice, back to photographic advice -- steadying techniques can be helped alot with varying types of bodily support -- anything from leaning against a wall or tree to crouching and propping your elbows on your knees. These techniques can become a habit with you.
Breathing/relaxing techniques also shouldn't be taken lightly. give it a try -- practice taking slow deep breaths and slowly letting go and see if you notice some bodily steadiness either at the top of your breath or after you let it out. That could give you a valuable clue as to taking shots.
And, of course, using a good fast shutter speed and flash when you can will both help a lot.
Tony
Snydremark
Gallery: 66 photos
Oct 10, 2010 11:26 |  #8
tonylong wrote in post #11068579 (external link)
...-- anything from leaning against a wall or tree to crouching and propping your elbows on your knees. These techniques can become a habit with you.
I use these a lot, actually...or, when out and about, the roof of the car, etc
tonylong
...winded
Gallery: 60 photos
Oct 10, 2010 11:37 |  #9
Snydremark wrote in post #11068632 (external link)
And, don't forget things like bean bags!
Tony
Ugly ­ Joe
Oct 10, 2010 12:35 as a reply to  @ tonylong's post |  #10
How about the "string monopod" idea?
https://photography-on-the.net …&highlight=stri​ng+monopod
Essentially, a piece of string attached to the bottom of your camera (tied to a quick-connect plate as an example), long enough to hang to the ground.
Step on the end, and pull upwards until the slack is out - should help reduce the shakes when your muscles only need to pull in one direction.
"Hell is an eternity of getting up at 4am to nothing but decaf coffee..."
A good friend will help you move.
A true friend will help you move a body.
An old friend more than likely will pass on either because of a bad back.
Snydremark
Gallery: 66 photos
Oct 10, 2010 13:49 as a reply to  @ Ugly Joe's post |  #11
That reminds me; if you use a standard camera strap, you can wrap that around yor forearm as a type of steadying sling.
1,186 views & 0 likes for this thread, 7 members have posted to it.
Shaking!
Latest registered member is EBiffany
1604 guests, 102 members online
