Thread started 10 Oct 2010 (Sunday) 11:09
Q: Lens centerline
evanger371
Oct 10, 2010 11:09 |  #1
Q1: Is the tripod socket always on the horizontal centerline of the lens for Canon EOS bodies?
Q2: Does anyone know if the vertical centerline dimensions (from the bottom of the camera) are published for Canon bodies (with and without grips)?
I am waiting for a new milling machine to arrive and will be getting back into some light fabrication. Among the first few projects will be L-brackets and camera/lens plates. I can measure the dimensions of my own equipment but I'm interested to how much these vary among the Canon bodies.
number ­ six
fully entitled to be jealous
Oct 10, 2010 17:45 |  #2
I've wondered that myself. I don't have my old 300D and 30D to compare any longer, though.
I've never seen an SLR where the tripod socket didn't look centered. But I've never measured carefully, either.
It's obvious that the 1D4 and the 50D have very different vertical distances to lens center.
What mill are you getting?
-js (amateur photographer, amateur machinist)
"Be seeing you."
50D - 17-55 f/2.8 IS - 18-55 IS - 28-105 II USM - 60 f/2.8 macro - 70-200 f/4 L - Sigma flash
evanger371
Oct 10, 2010 23:06 |  #3
Hi JS,
I'm getting the Grizzly G0704 mill at the end of the month and very excited about it. It'll be a HUGE improvement over the old Sieg X1 plaything I had.
Maybe I'll start collecting data for this and take a set of calipers with me to Costco and the camera stores. ;-)a
BTW -- Is that a Lotus Seven or Caterham in the avatar?
cheers,
--eric
joeseph
"smells like turd"
Gallery: 263 photos
Joined Jan 2004
Oct 11, 2010 02:37 |  #4
evanger371 wrote in post #11068560 (external link)
can't confirm "always" but:
10D = yes
20D = yes
1D Mk II = yes
1D Mk III = yes
TF posting: here :-)
apersson850
Gallery: 35 photos
Oct 11, 2010 02:49 as a reply to  @ joeseph's post |  #5
Probably always.
It's at least true for the EOS 10, EOS 30, EOS 400D, EOS 40D and EOS 7D too.
Back in the even older days it was true for the EF, F-1 and T90 as well, so I think they have a tradition here.
Anders
DetlevCM
Oct 11, 2010 05:23 |  #6
I couldn't see why it wouldn't be on the horizontal centre line - looks centred on the 5D MK II too.
On that note though - Adding a Canon grip shifts it slightly...
5D MK II AF Satisfaction Poll | Reduced Kit List
A Basic Guide to Photographyexternal link | Websiteexternal link
Flickrexternal link | Artflakesexternal link | Blurbexternal link
hpulley
Oct 11, 2010 06:41 |  #7
It isn't true for many P&S cameras, at least non-Canon. For many the plastic (ug) tripod socket is wherever they can fit it between the battery and memory card doors etc. It is an afterthought for most P&S as few will ever be used on a tripod.
flickr (external link) 1DIIN 40D 1NRS 650 1.4xII EF12II Pel8 50f1.8I 28-80II 17-40L 24-70L 100-400L 177A 199A OC-E3 RS-80N3
apersson850
Gallery: 35 photos
Oct 11, 2010 08:16 as a reply to  @ hpulley's post |  #8
The grip comment is correct. I haven't thought about that before, but looking under my gripped 7D, I see the thread is indeed shifted a bit.
Anders
hpulley
Oct 11, 2010 08:34 |  #9
apersson850 wrote in post #11074344 (external link)
Sadly, they have to do it with cheesy add-on grips because the grip screws into the original tripod mount and in making the grips as slim as possible they can't put the tripod socket directly underneath the original socket. Yet another reason to get a 1D, no cheesy screw on grip required :lol:
DetlevCM
Oct 11, 2010 09:22 |  #10
hpulley wrote in post #11074447 (external link)
I don't think that's the reason - I don't think the socket sits between the batteries - so slimness shouldn't be the issue.
Jim_T
Joined Nov 2003
Oct 11, 2010 09:38 |  #11
In their reviews, dpreview.com has claimed that the tripod mount is aligned exactly with the centerline of the lens... I've seen this in a few Canon camera reviews done by them going back to the 20D . (I don't know where they get their information, or if it's true).
For the 550D/T2i review, they also claim that the mount is aligned with the focal plane of the sensor..... http://www.dpreview.co​m …ws/canoneos550d​/page5.asp (external link)
Rabies
Oct 11, 2010 09:46 |  #12
The tripod mount is aligned with the horizontal centreline of all EOS bodies I've handled (450D, 30D, 40D, 50D, 7D, 5Dc, 5DII, 1DIIn, 1DsIII) but not with the sensor plane (that is marked by a circle with a line through it on the prism housing.) Centre height varies by model and is best measured individually.
7D | 40D | EF-S 10-22 | EF-S 17-55 f/2.8 IS | EF 70-200 f/2.8L IS II | EF 1.4x II | S90 | full list
evanger371
Oct 11, 2010 10:01 |  #13
:) Thanks for all of the input and references.
DetlevCM
Oct 11, 2010 12:26 as a reply to  @ evanger371's post |  #14
DetlevCM wrote in post #11074656 (external link)
I need to correct myself- home now - the tripod mount does sit between the batteries - to be honest though, they could make the grip a bit thicker and the issue would be solved.
hpulley
Oct 11, 2010 12:40 |  #15
DetlevCM wrote in post #11075666 (external link)
I thought so as well though this is a bit odd really, the original PB-E1 on the EOS-1 had the tripod mount in parallel to the case so it could be placed anywhere between the AA battery caddy and the NC-E1 bottom was obviously shaped to fit as well. The two small battery design meant the tripod mount has to be perpendicular but it isn't that tall really, I bet a grip of 1/4" or 7mm or so higher would have let them mount it anywhere...
That said, going back further the original Canon Power Winder A does not put the tripod mount in the same spot, go figure.
5,102 views & 0 likes for this thread, 8 members have posted to it.
Q: Lens centerline
1467 guests, 188 members online
