Thread started 11 Oct 2010 (Monday) 14:30
Remote Shutter Release Cord Dead
jjenkins11
Oct 11, 2010 14:30 |  #1
My Canon Remote Shutter Release Cord has died. Isn't this just a dry contact? I opened it up and nothing seemed wrong with it. Could there be a problem on the camera side? Can't I just put a meter on the cord to check it?
40D & 60D
24-85mm, 60mm, 100mm, 100-400mm L
http://www.frozentimep​hotography.net (external link)
tvphotog
Oct 11, 2010 16:24 |  #2
The wasted time is probably worth buying a new one for a few bucks at www.dealextreme.com (external link).
Jay
Ireland in Word and Image (external link) Jay Ben Images (external link)5D IV | 5DS/R | Sony RX100 V | 24-105L | 100-400 IIL | 16-35 f/2.8 IIL | 24 T/S f /3.5L II | 17 T/S f/4L | 50mm f/1.2L | 35mm f/1.4L | 70-200 f/2.8L II | 580 EX II | 600 EX-RT | Feisol 3441T/Markins Q3T lever QR | Gitzo 3542L Markins Qi20 BV-22 | Gitzo 5561T RRS MH-02
DetlevCM
Oct 11, 2010 16:26 |  #3
jjenkins11 wrote in post #11076336 (external link)
If you have been coiling it up every time you stored it, my guess would be that you overstressed the cable and it broke internally - the same can happen to headphones, laptop power cables etc.
5D MK II AF Satisfaction Poll | Reduced Kit List
A Basic Guide to Photographyexternal link | Websiteexternal link
Flickrexternal link | Artflakesexternal link | Blurbexternal link
Saint728
Oct 11, 2010 20:46 |  #4
Which Canon Remote Shutter Release model do you have? I would check the battery inside it first, it could be flat.
Take Care,
Cheers, Patrick
Canon EOS 1Ds Mark III | 17-40mm f/4.0L | 70-200mm f/2.8L USM | 100mm f/2.8L IS Macro | 300mm f/4.0L IS
Click Here To See My Gear
Click here to see my Flickr (external link)
http://www.runryder.co​m/helicopter/gallery/9​019/ (external link)
joeseph
"smells like turd"
Gallery: 263 photos
Joined Jan 2004
Oct 11, 2010 22:14 |  #5
camera side is easy to check, see: http://martybugs.net …ear/CanonN3Conn​ector.html (external link)
a quick test with a small screwdriver to gently short out the ground-to-focus and then ground-to-shutter pins will likely tell you the camera's fine.
If the cord you have is a RS-80N3 or eBay variant, then checking continutiy between the plug pins and the switch can be done with an ohmmeter, as can the switch itself.
As has been mentioned above, its likely the cable has let go somewhere between the switch & plug - probably where the cable enters the plug...
TF posting: here :-)
1,412 views & 0 likes for this thread, 5 members have posted to it.
641 guests, 122 members online
