It is so hard to get my grandson to be still long enough to actually take a picture. He has a huge bruise on his forehead, the reason it is in B&W. Trying to improve my skils, if any, so I can take better pics. Any comments?
timmysgirl Hatchling 7 posts Joined Oct 2010 More info | Oct 12, 2010 14:58 | #1 It is so hard to get my grandson to be still long enough to actually take a picture. He has a huge bruise on his forehead, the reason it is in B&W. Trying to improve my skils, if any, so I can take better pics. Any comments?
MadTony Senior Member 430 posts Likes: 7 Joined Feb 2005 Location: Colorado More info | Oct 12, 2010 22:35 | #2 A bit low contrast for my taste... Adam Pender
Oct 13, 2010 00:26 | #3 I agree that it's a little flat, the flash isn't helping with that either. Try to get him outside maybe? You don't necessarily need him to pose for you to get a good shot. Get him outside, let him be a kid, and get a shot of that. I think it will be better as a photograph, but also as a memory to look back when he's older.
Oct 13, 2010 08:31 | #4 Thank you, will use that info next time. What do you mean by flat? Just that it is in BW and doesn't show much depth? I am new and could use all the info I can get my hands on.
vpnd Goldmember 1,483 posts Joined Oct 2007 Location: nd More info | Oct 13, 2010 09:33 | #5 The full on flash is what "flattens out" this image. I would suggest looking at the direction and quality of light. try this exercise. take a test subject (probly not the little guy, but the hubby) have them stand about 3 feet from the sliding glass door in the kitchen or a large window. have them face the window and circle around subject and shoot all the way around. have them then turn 90 degrees and repeat. repeat process untill you can tell what the direction of light is doing to your subject. this will create depth and tonal contrast that is pleasing to view. Next notice that flash and digital don't usually mix well. the quality of light using front on flash is almost always harsh. Getting a fast lens will allow you to shoot without flash in lower light. If price is an issue, the 50 1.8 is around 100 dollars. Canon "Snappy".... Thanks Mom and Dad!
Oct 13, 2010 10:23 | #6 vpnd wrote in post #11088640 The full on flash is what "flattens out" this image. I would suggest looking at the direction and quality of light. try this exercise. take a test subject (probly not the little guy, but the hubby) have them stand about 3 feet from the sliding glass door in the kitchen or a large window. have them face the window and circle around subject and shoot all the way around. have them then turn 90 degrees and repeat. repeat process untill you can tell what the direction of light is doing to your subject. this will create depth and tonal contrast that is pleasing to view. Next notice that flash and digital don't usually mix well. the quality of light using front on flash is almost always harsh. Getting a fast lens will allow you to shoot without flash in lower light. If price is an issue, the 50 1.8 is around 100 dollars. Thank you very much. I will try that out.
Snydremark my very own Lightrules moment More info | Hey! I'm reasonably sure we used to have that couch
Boosted exposure just a tiny bit Boosted the blacks a small amount Increased clarity (boost to mid-tones A couple of small Tone Curve adjustments to increase the contrast Mild amount of sharpening and a slight bit of noise reduction I'm far from an expert with B&W, either, but it gives you an idea of where you can go with an image like that. - Eric S.: My Birds/Wildlife
Oct 13, 2010 12:02 | #8 Wow, I can see alot of difference. Thanks. Thanks to everyone for the input, I appreciate it very much.
JimMcrae Senior Member 938 posts Joined Aug 2007 Location: Edinburgh More info | Oct 13, 2010 17:26 | #9 I like the original shot and don't mind the crop at all, but agree it's a bit flat. Snydermark's edit, however, is some piece of work! 60d, 400d, 100-400mm f/4.5-5.6, 24-105mm f/4, 50mm f/1.4, 580ex II, 2 X 430ex II, Bowens 500, cs5
| Latest registered member was a spammer, and banned as such! 2685 guests, 153 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
