Thread started 13 Oct 2010 (Wednesday) 15:32
Prime Focus Problem
devildog2222
Oct 13, 2010 15:32 |  #1
I know there is a thread already about this, but none of the fixes work in my case. Ok, I have the T-Ring, Orion Combined Camera Adapter 1.25 and the part that screws on to the adapter and then slides into the Focuser. Well out of trial and error, I took off the adapter. So now its just the T-ring and the piece that goes into the focuser. The problem is that it still wont focus, I can tell that I just need to be a few cm or mm closer and I will have a perfect focus.
I was able to get a picture of M42 but that was with the barlow lens.
Here is a pic of the setup.
Jeff
Oct 13, 2010 17:55 |  #2
I think this is a common problem with Newts. Check scopestuff.com for a low profile adapter. That'll probably give you the infocus distance that you need.
Jeff
70D | Tokina 12-24 | Tamron 17-50 f/2.8 | Canon 28-135 IS| 430EX
Astrophotograpy: QHY268m, Astronomik Deepsky LRGBHaO3S2 filters, Meade 10" SCT, Astrotect 130EDT APO (.8x), iOptron CEM60 to keep it all off the ground.
MY AIRPLANE PICS (external link) | MY ASTRO PICS (external link)
Nighthound
Gallery: 224 photos
Best ofs: 24
Oct 13, 2010 20:22 |  #3
Jeff nailed it, low profile is what is required. It's very common to be just a hair away from focus, very frustrating. I would take an accurate measurement of the adapter rise outside the focuser and ask the person you contact to give you the measurement of their adapter to be sure it's lower. You've got plenty of back focus so be sure you get a low enough profile to get past focus on the in travel and that the adapter won't hit your secondary mirror when inserted.
Steve
devildog2222
Oct 14, 2010 14:17 as a reply to  @ Nighthound's post |  #4
I was looking through my dads astrophotography gear and I think I found what I need to get the focus. It seems to give a lower profile, also the silver ring comes off don't know if that make it even closer.
martyn_bannister
Oct 14, 2010 15:22 as a reply to  @ devildog2222's post |  #5
I still haven't got my scope collimated spot on, but one thing I did find is that, given the range of adjustment of the collimating screws, the primary mirror can be angled for correct collimation with the mirror at any distance from the open end of the scope. i.e. the collimating screws can be adjusted all the way in, in the middle, or all the way out and the angle of the primary mirror can still be correct. The effect of this in my case was to make it impossible to focus a normal eyepiece, because the focus tube had to be wound all the way out and it still wouldn't quite focus. However, I also noticed that I COULD get prime focus with my DSLR.
It turned out that I had the primary mirror too close to the open end of the scope. Unwinding all the collimating screws equally moved the primary back and allowed me to focus the eyepiece correctly. Unfortunately, this meant that I LOST prime focus with the DSLR! If I can get the primary somewhere in-between, I should be able get both the DSLR and normal eyepieces to focus.
It occurs to me that this might also be the cause of you not being able to get prime focus?
I hope this makes sense.
Rgds,
Nighthound
Gallery: 224 photos
Best ofs: 24
Oct 14, 2010 15:42 |  #6
That certainly looks like it should do it. Good luck and post some shots.
Steve
devildog2222
Oct 15, 2010 13:06 as a reply to  @ Nighthound's post |  #7
It did work, tried it on M45 last night.
martyn_bannister
Oct 15, 2010 13:24 |  #8
devildog2222 wrote in post #11103119 (external link)
So can we see the results please :)
devildog2222
Oct 15, 2010 13:27 as a reply to  @ martyn_bannister's post |  #9
Click on the link to view my post of M45. Its not the best picture. I didn't have a lot of time so I just did some quick testing.
https://photography-on-the.net/forum/showthre​ad.php?t=945488
1,922 views & 0 likes for this thread, 4 members have posted to it.
Prime Focus Problem
1872 guests, 105 members online
