I don't know of any drop-in ND filters for the 200 f2L, and I don't know if other ND filter designs, like the Lee big stopper, will work with the 200. Has anyone found an ND filter solution for this lens? Thanks.
sdipirro Goldmember 2,207 posts Likes: 46 Joined Dec 2005 More info | Oct 14, 2010 13:59 | #1 I don't know of any drop-in ND filters for the 200 f2L, and I don't know if other ND filter designs, like the Lee big stopper, will work with the 200. Has anyone found an ND filter solution for this lens? Thanks. Cameras: 1DX, 1D4, 20D, 10D, S90, G2
TaDa ...as cool as Perry 6,742 posts Likes: 3 Joined Feb 2008 Location: New York More info | Oct 14, 2010 18:38 | #2 The Big Stopper will be too small. The diameter of the 200L is 5 inches and the Big Stopper is 4"x4". You could get a Singh-Ray X-Pro size 5 stop filter which is 5.1 inches x 6.8 inches, but you'd have to hand hold it in front of the lens carefully so that light wouldn't leak in if it were slightly off. Name is Peter and here is my gear:
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Oct 14, 2010 18:49 | #3 An easier solution might be to just get the 200 f/2.8 L. Jon
Oct 15, 2010 11:55 | #4 Well, I have the 70-200 f2.8L, but the 200 f2l makes a great portrait lens at f2, but outdoor lighting often doesn't make it possible for me to shoot at f2 or anything close to that unless I just use natural light (which I've done). So would an ND gel filter accomplish the same thing? I hadn't thought to try that, and I even have some ND gel sheets at home. Guess I need to take a look at the gel filter holder that I've never removed from the 200 f2L. Cameras: 1DX, 1D4, 20D, 10D, S90, G2
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Oct 16, 2010 19:56 | #5 Yeah. ND is ND - doesn't matter what the material is, just get the density you want. Jon
Oct 16, 2010 21:52 | #6 The manual for the 200 F2L shows you exactly how to cut down a filter to fit into the drop in filter holder. Kodak Wratten gel filters are the most common to cut down. Teddy Smith, SOC
| Latest registered member is semonsters 1700 guests, 139 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
