Hey everyone,
I am currently taking a class at Hopkins called the Visual System, and one of the first things we discussed this semester was the anatomy and phototransduction circuitry of the human visual system. One of the things we talked about was chromatic aberration, which is the inability of a lens system to bring 3 wavelengths of light (R/G/B) into focus at the same point.
Many people like to talk about lens aberrations when comparing different lenses, but have you ever thought about the chromatic aberration present in the human retina? I thought that some of you might be also interested in learning a bit about how our visual system deals with chromatic aberration.
Plus, I had a test earlier this week, so I typed out most of this stuff as review anyway. So I figured, why not post it on the forums and see if anyone finds it interesting
First, some basics. People with normal color vision have three populations of cone photoreceptors, each with a different photopigment within them. There are long-wavelength (called L or red) cones, medium wavelength (Called M or green) cones, and short wavelength (called S or blue) cones. The blue cones have a max absorption at around 440nm, while the green and red cones absorb best at 533 and 565nm, respectively.
Herein lies an inherent problem. With a simple optical design (such as our eye), it is not possible to focus 3 wavelengths of light to a single point. This is called chromatic aberration, and it has the effect of making some wavelengths appear blurry since they are not all focused perfectly onto the retina (or sensor, if we're talking about cameras). Lens manufacturers use sophisticated optical designs and special lens elements (such as fluorite) to deal with these aberrations, but it is simply not practical to build a lens system with 10 or more special lens elements in the human eye (imagine how much your eyes would bulge out of your head, haha). So, how does the human eye, with its single lens, deal with chromatic aberration?
1) The human retina uses long wavelength light as a guide. These long wavelengths are focused perfectly on the retina. As a result, the slightly shorter wavelengths corresponding to green will be focused very slightly in front of the retina. This is not a big issue because the peak absorbances of the L and M cones are relatively close together. However, the peak absorbance of the S cones are far apart from the other two, so they really take a hit here. Short wavelengths (i.e. blue) and are focused considerably in front of the retina as a result. So, instead of blue light being focused onto the retina as a sharp point, they appear more like blur circles. It's not hard to see how that is detrimental to visual acuity. So what happens to the short wavelengths?
2) The area of your retina specialized for high acuity vision (the macula) is covered with a yellowish pigment. This can be thought of as a UV filter of sorts, since it essentially prevents most short wavelength light from reaching the areas responsible for precise vision. In addition, the center of the fovea (fovea is center of the macula and the region of highest visual acuity) is stuffed full of L and M cones and has no blue cones. The retina is essentially working around the chromatic aberration issue by ensuring that short wavelength light is not used for precise vision.
3) So what is the purpose of the blue cones? Even though they are not used for precise vision, they contribute to our ability to see color. In fact, the signals from the S cones are kept separate from the other two all the way to the primary visual cortex in the back of your brain.
So there you go. The structure of our retina and the processing circuitry present in our brain elegantly take care of the issue of chromatic aberration. And our visual system doesn't even need fluorite glass to do it
Hope you guys found this interesting in some sense.
