I'm not in the market for a 60D (I have a 7D and if you've read my previous comments on it, you'll see that I think it's very nearly perfect). But if I were considering moving up from a 40D or 50D, one of the big considerations would be the ease with which I could select the autofocus point.
On the previous XXD and XD cameras (excluding the 1D series), you can configure the camera to make autofocus selection with the joystick possible. And the joystick is located where it's easy to get at when you're holding the camera to your eye: just move your thumb off the dial and the joystick is right there, positioned right under your thumb. You don't have to contort your thumb or anything to use it. The placement is excellent.
On the 60D, the "joystick" is integrated into the rear dial assembly. It looks to me like its position is much worse for use when selecting the autofocus point, in part because it's now possible to bump the rear dial accidentally while fiddling with the joystick, and in part because it's now also possible to hit the "set" button when moving your thumb from one joystick direction to another.
But that's just my impression. My question is, then: how well is that "joystick" working for you in practice for selecting the autofocus point quickly and painlessly? Your comments will be especially valid if you have previous experience doing this with the joystick on the other XXD or XD cameras.
