Yes, I feel silly asking this so no need to rub it in, but I'm sure I'll get a helpful answer from someone here. What does the lock switch on the 7D do? The only mention I've found for it is on pg 37 and it says to make sure it's switched to </> which I assume is on. Further down the page if says I can do the same action even if it's switched to off.
I've had a bit of a play around and I can alter settings whether it's on or off. What am I missing here?
