FORUMS Post Processing, Marketing & Presenting Photos The Business of Photography
Thread started 16 Oct 2010 (Saturday) 04:27
Do you mount on mdf, foamcore, etc
mitch.mccabe
Oct 16, 2010 04:27 |  #1
Hi guys and gals, I've tried searching the forums but cant to much info on this. I have a company that prints my photos, they send them to me, i also use a framing company that i buy frames from, that come with the matboards.
I then use backing tape to stick the photo to the mat board,then put the mat/photo onto glass and then put the mdf that comes with the frame in behind the mat/photo but i dont get that really flat look. There is still some curves in the photo.
My question is what do you pros use to stick your photos onto before putting them into frames.
I've heard of foamcore (but heard it breaks apart after time)
The mdf which if it gets humid it can warp
Rencently heard of sticking the photo onto a sheet of alluminium
But heard that glues are acidic and can discolour the photo.
I'm stuck as i want my end product to look pro and to last,
I'm in Australia so if any aussie pro's can point me in the right direction it would be great
Canon 50d / 18-200IS / 17-40 f4L / Nifty Fifty 1.8 / 70-200IS f2.8L Canon 430exII
"Both good and bad days should end with productivity. Your mood or affairs should never influence your work"
mitch.mccabe
Oct 16, 2010 15:59 |  #2
Anyone can answer this, not just aussies!!!! Please help
thecackster
Oct 16, 2010 17:39 |  #3
Foam core
mitch.mccabe
Oct 16, 2010 18:18 |  #4
What do you use to stick the photo to the foam core mount?
thecackster wrote in post #11109640 (external link)
Foam core
D.C.
Oct 16, 2010 23:50 |  #5
My wife has done a lot of framing. Just attach photo to mat with acid free linen tape. Foam core just lays against picture. It should lay flat. Some paper is harder to deal with.
Duane
7D, 430EX,10-22, 100 Macro, 100-400, 24-105, 500 F/4 IS
My Gallery (external link)
Jimconnerphoto
Oct 16, 2010 23:53 |  #6
#1 Double weight board.
When its a big print i may use Gatorfoam
You can get it with adhesive peel and stick.
Wedding and Portraits www.jimconnerphoto.com (external link)
Commercial Work www.jamesdconner.com (external link)
Mike22487
Oct 17, 2010 22:46 |  #7
I know a lot of rubber cements are acid free, I have used elmers brand rubber cement to glue the photo to foamcore before
thecackster
Oct 18, 2010 11:02 |  #8
mitch.mccabe wrote in post #11109813 (external link)
There is this great adheasive from 3M that i've used, comes in rolls. Basically what i do is peel it, and stick it to the back of the print, cut it to size. Then I stick the photo to the foamcore, and trim the excess. The key is to keep a very sharp blade at all times and use a straight edge to keep from making wavey cuts or screwing up your print.
krb
Oct 18, 2010 11:17 |  #9
thecackster wrote in post #11119079 (external link)
3M Positionable Adhesive.
-- Ken
Gear list
thecackster
Oct 18, 2010 11:50 |  #10
krb wrote in post #11119157 (external link)
Ah thats it! Thanks! Monday morning, brain not quite fully functional yet. :)
5,142 views & 0 likes for this thread, 6 members have posted to it.
1167 guests, 134 members online
