So which lenses designed for APS-C crop bodies also work on Full Frame? Which ones work on APS-H crop bodies?
I have one I can vouch for - Tokina 11-16 f/2.8. It works on my 1D from 13-16 and on my 5D at 16.
n1as Goldmember 2,330 posts Likes: 25 Joined Oct 2007 Location: Salem, OR More info | Oct 16, 2010 10:28 | #1 So which lenses designed for APS-C crop bodies also work on Full Frame? Which ones work on APS-H crop bodies? - Keith
G-Tus Member 36 posts Likes: 1 Joined Jun 2010 More info | Oct 16, 2010 10:35 | #2 No Canon EF-S lenses physically fit on FF or APS-H, because of the rubber ring at the rear.
thenextguy Goldmember More info | Oct 16, 2010 10:51 | #3 If I'm not mistaken, all non-Canon lenses are EF mounts, even the ones that are designed for crops. So they'll all fit on full frame, but they may not work at all focal lengths. Steve -- Website
Oct 16, 2010 11:11 | #4 Let me clarify the question. Yes, I know that EF-S lenses have non-compatible mounts (but can be easily modified) and that non-Canon lenses all use standard EF mounts. - Keith
Oct 16, 2010 11:23 | #5 10-22mm works well on a APS-H sensor at 12 mm and above. The tokina 11-16 is known to work at 13mm, and the 30mm F1.4 sigma will also work. Not sure how any of these will work on a full frame but I assume not well without some heavy cropping. "I work from awkwardness. By that I mean I don't arrange things. If I stand in front of something, instead of arranging it, I arrange myself" -Diane Arbus
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Oct 16, 2010 11:31 | #6 For the newbies who may not fully understand the stuff above: Skip Douglas
Oct 16, 2010 12:07 | #7 Thanks Skip - You're absolutely right. Before I mount any "digital only" lens on my 1D or 5D, I very carefully compare it to one of my EF lenses. I check to see that nothing projects from the digital-only lens at all zoom and focus settings. If it stick out more than my EF 85 f/1.8, then it does NOT go on the FF body. - Keith
JelleVerherstraeten Goldmember 2,440 posts Likes: 1 Joined Dec 2008 Location: Antwerp, Belgium More info | Oct 16, 2010 13:04 | #8 |
xarqi Cream of the Crop 10,435 posts Likes: 2 Joined Oct 2005 Location: Aotearoa/New Zealand More info | Oct 16, 2010 13:48 | #9 I'm going to go with "none".
LowriderS10 Cream of the Crop 10,170 posts Likes: 12 Joined Mar 2008 Location: South Korea / Canada More info | Oct 16, 2010 14:00 | #10 JelleVerherstraeten wrote in post #11108561 The tokina 11-16 is a ef-s lens, but you can use it at 14-16mm without vignetting. It's not an EF-S lens. It's an EF lens designed for crop bodies. There's a slight difference. -=Prints For Sale at PIXELS=-
Panchdara Member 124 posts Joined Jul 2010 Location: Isle of Man More info | Oct 16, 2010 15:39 | #11 LowriderS10 wrote in post #11108748 EF lens designed for crop body: can be mounted on FF with no physical damage as the rear element does not protrude, but will likely vignette at some or all of the way through the focal range
bohdank Cream of the Crop 14,060 posts Likes: 6 Joined Jan 2008 Location: Montreal, Canada More info | Oct 16, 2010 15:46 | #12 My 10-22, ring removed, worked from 12-22. I never tried it at 10-11mm. Moot point since it vignetted below 15mm...so perfectly useable from 15-22. Bohdan - I may be, and probably am, completely wrong.
Wilt Reader's Digest Condensed version of War and Peace [POTN Vol 1] More info | Oct 16, 2010 15:48 | #13 Lenses can have EF-S mount, or EF mount; EF-S mount will not physically mount on FF (EF) bodies unless some physical modification of the lens is performed. You need to give me OK to edit your image and repost! Keep POTN alive and well with member support https://photography-on-the.net/forum/donate.php
SkipD Cream of the Crop 20,476 posts Likes: 165 Joined Dec 2002 Location: Southeastern WI, USA More info | Oct 16, 2010 17:50 | #14 Panchdara wrote in post #11109092 Sorry, I'm new to this but this statement confuses me... what EF lens was are specifically designed for a crop sensor? - I mean APS-C (1.6)? The third party (Sigma, Tamron, etc.) lenses that are labelled "digital only" or some variation of that are all EF mount lenses, but they have a narrower image cone than EF mount lenses designed for 35mm film format cameras. These lenses, if used on a 35mm film format camera will generally vignette rather badly. However, they cannot cause mechanical problems with the larger format cameras because their parts don't go any deeper into the mirror box than the Canon EF protocol dictates. Skip Douglas
| Latest registered member is semonsters 1509 guests, 130 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
