If Canon were to build a 24-105mm L f/2.8 based on current designs:
- How heavy would it be?
- What filter size would it likely take?
- What would it cost? (assuming current pricing structure)?
evanger371 Senior Member 309 posts Likes: 1 Joined Feb 2010 Location: Central New Jersey More info | Oct 16, 2010 19:33 | #1 If Canon were to build a 24-105mm L f/2.8 based on current designs:
JonK Goldmember 2,161 posts Likes: 3 Joined Feb 2004 Location: PA USA More info | Oct 16, 2010 22:58 | #2 It would be heavy 7NE | 7D | 5DII | 16-35/2.8L II | 24/1.4L II | TS-E 24/3.5L II | 50/1.4 | 85/1.2L II | 100/2.8L IS | 70-200/2.8L IS II | 400/5.6L | PIXMA Pro 9500 Mark II
richardfox Goldmember 1,883 posts Joined Oct 2009 Location: Bellbrook, Ohio, USA More info | Oct 16, 2010 23:03 | #3 •How heavy would it be? - Too heavy!•What filter size would it likely take? - Too big!•What would it cost? (assuming current pricing structure)? - Too much! Canon 50D gripped, EF 50/1.8, EF-S 10-22, 17-40L, 24-105L, 70-200 f/2.8L, 100/2.8 macro, 100-400L, 300 2.8L, Canon 500 f8 mirror with chipped EF mount, 580EX, 1.4x and 2x Canon teleconverters, Canon EF Life-Size converter.
Twister286 Member 63 posts Joined Jul 2010 More info | Oct 17, 2010 00:49 | #4 Whatever dimensions it has, it wont be any larger than the 70-200/2.8 series... 50D | 430EX-II
cogliostro Member 239 posts Joined Dec 2009 More info | Oct 17, 2010 00:55 | #5 Twister286 wrote in post #11111332 Whatever dimensions it has, it wont be any larger than the 70-200/2.8 series... 200/2.8 needs more glass than 105/2.8...simple. Not really, because the diameter also equates to the vignetting. That's why even for lenses like 17 mm F4 or 14 mm F2.8 have humongous glasses, even though theoretically they only need very small opening for the aperture. 5d2 and glasses
rossbeckernz Member 41 posts Joined May 2010 Location: Wellington, New Zealand More info | The reason the wide angles are so big is that are retrofocus (inverted telephoto type) designs & not true wide angle lenses. Ross Becker,
| Latest registered member is Monkeytoes 1467 guests, 188 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
