Working with the tethered 'live-view', 'focus-nudging', technique described by John_N, in this posting:
https://photography-on-the.net/forum/showthread.php?t=945582
(hopefully he didn't patent, nor copyright, that method)
Obtained this - 57 separate images stacked using Zerene.
Canon 50D, tethered to my laptop, utilizing EOS Utility, 100mm Macro, ISO 100, f2.8, 37mm extension tubes, auto-focus, approx. 6 inches from lens to subject, 'butter-tub' diffuser - used 'intermediate' focus bump.
Berries are approx. 1/4-inch (6mm) diameter.
Berries were released back into 'the wild' after posing -
I realize that there is some 'ghosting' between the berries and the leaves/stems - this was done more as an experiment in the technique rather than working towards a great final image.
Also experiment with first cross-eyed stereo-gram - not anywhere near as good as Lord V's - I think perhaps too much lateral distance between shots??
Adding the focus stepping code should be a no-brainer though.
