Is there an adverse affect when you create (reasonably) many directories, maybe a 100-200 on an external drive.
aam1234 Goldmember 4,132 posts Likes: 1 Joined May 2004 More info | Aug 27, 2005 13:31 | #1 Is there an adverse affect when you create (reasonably) many directories, maybe a 100-200 on an external drive.
ByteTheBullet Member 94 posts Joined Dec 2004 Location: U.S.A More info | Aug 27, 2005 19:27 | #2 The only thing I can think of would be that the root, i.e. D:\, may be limited to a certain number, but sub directories should be fine. I am not sure if this is still an issue. WinXP and NTFS may not care.
davepgh1 Senior Member 303 posts Joined Apr 2005 Location: Pittsburgh More info | Sep 01, 2005 21:17 | #3 The fix is in, bring them on.
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Sep 01, 2005 22:27 | #4 A drive's a drive, doesn't matter where it is. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
Robert_Lay Cream of the Crop 7,546 posts Joined Jul 2005 Location: Spotsylvania Co., VA More info | Sep 02, 2005 00:00 | #5 aam1234 wrote: Is there an adverse affect when you create (reasonably) many directories, maybe a 100-200 on an external drive. Thanks Should we assume that the "external" drive is via a USB port? Bob
| Latest registered member is Thunderstream 1301 guests, 119 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
