Hi anybody using the expodisc for white balance.
I'm wondering how beneficial they are also is there much of a difference between the neutral and the portrait models .
Thanks in advance.
Alan
Oct 18, 2010 12:01 | #1 Hi anybody using the expodisc for white balance. www.Marinelliphotography.com
lannes Goldmember 4,370 posts Likes: 6 Joined Dec 2009 Location: Perth, Australia More info | Oct 18, 2010 12:39 | #2 I use BaLens WB lens caps and I have never used the portrait dome. I think a lot of photographers are fixing WB in pp nowadays. 1Dx, 1DM4, 5DM2, 7D, EOS-M, 8-15L, 17-40L, 24 TSE II, 24-105L, 50L, 85L II, 100L, 135L, 200L f/2.8, 300L f/4, 70-200L II, 70-300L, 400Lf/5.6
tvphotog Cream of the Crop More info | Oct 18, 2010 13:48 | #3 I used WhiBal for a while and then realized that shooting RAW, I could set whatever Kelvin value I wanted in Camera Raw. I haven't used the WhiBal in about a year. I don't think it's worth the money for you to get the ExpoDIsc. Sounds good, but with Auto and Camera RAW, you don't need it. Jay
plasticmotif Goldmember 3,174 posts Likes: 2 Joined Sep 2008 Location: Tennessee More info | Oct 18, 2010 15:54 | #4 I shoot auto white balance all the time in raw. Camera Raw to adjust the temp. Kelvin. Mac P.
Snydremark my very own Lightrules moment More info | I have one of the neutral discs, but I've found it is just easier to get as close as I can with the in-camera presets and tweak the final result in Lightroom; I haven't used the disc in months. - Eric S.: My Birds/Wildlife
tgara Goldmember 2,336 posts Likes: 8 Joined Sep 2007 Location: Connecticut, USA More info | I have on, the neutral model. It works great, as others have said. But if you shoot raw, you can adjust the white balance in post, so it has less value with these files. EOS 5D Mark III
Thanks to everyone for the great replies I do most of my white balance correcting in pp I was just looking to save a little time out of the camera I've also tried the coffee filter method with good results . www.Marinelliphotography.com
Snydremark my very own Lightrules moment More info | Honestly, the in-camera presets, on the 7D at least, do a pretty good job most of the time. Taking it off AWB and using those will probably save you as much time as using an Expodisc or similar. - Eric S.: My Birds/Wildlife
n1as Goldmember 2,330 posts Likes: 25 Joined Oct 2007 Location: Salem, OR More info | Oct 18, 2010 20:43 | #10 I use mine from time to time. Sometimes, with odd or mixed lighting, there is just no good way to get tweak it visually in Lightroom. The Expodisc helps in those situations. That said, I really do hardly ever use mine. - Keith
chestercopperpot Senior Member 996 posts Likes: 1 Joined Dec 2006 More info | Oct 18, 2010 21:48 | #11 Most of the time I just tweak in lightroom or camera raw, but when I do portraits I use the color checker passport, and then use that for the custom WB later. The results with that spot on. Michael
| Latest registered member is griggt 1089 guests, 126 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
