I've owned D30, then the D70 and now a 20D - each one an improvemnet on the other
I'm striving for clear focus and superb white balance performance to reduce the amount of post production work to get a decent image.
The D30 was slow to boot and produced "yellow" or brassy looking images.
The D70 produces OK white balance and focuses sharp and does a good job at fill flash (near natural lighting)
I bought the 20D hoping to see improvements on color - and am struggling to get it right.
I may be expecting too much from these cameras still or I just simply not have my mojo tamed yet.
I have the best luck with simply setting the 20D at sunlight and forget about any other setting. When I set the manual white balance, much in the same way as any other camera in the past, the resultant skin tones are too yellow-red. In PS I have to use hue on RED to move it to the right (green) and then select YELLOW and move that to majenta (left) then lighten the yellow to get pleasant skin tones for both the screen display as well as print out nicely.
I have also replied on a custom paramter setting which is "0" on all settings except "color" - I move that to the far right.
I also do not get good focus at all. After update to firmware 2.0.0 - focus has gotten weird. All my lenses now have difficulty focusing. I find that ssometimes I HAVE to go to manual mode because focus is going past focus one way and back again and gets into a cycle of back and forth and back and forth seeking focus under sunny or shaded conditions within the range that the camera should handle just fine.
Even when I go to manual focus - close range focusinf seems very fuzzy even though I get a steady "in focus" light.
I'm wondering if anyone esle has there same thoughts or issues?
Jacques
