Thread started 18 Oct 2010 (Monday) 17:32
green screen
Photofun42
Joined Jun 2010
Oct 18, 2010 17:32 |  #1
I am wanting to do green screen outside any advice.Thanks:)
ajaffe
Oct 18, 2010 22:28 |  #2
Take a green screen and hang it outside?
www.jaffe.photo
Rivest
Oct 18, 2010 23:21 |  #3
ajaffe wrote in post #11122966 (external link)
bw!
Hi, I'm David.
dmf
Oct 18, 2010 23:30 |  #4
If you have no green screen you can use any colour you like but not one that is anywhere in your shot.
Canon EOS 450D - EF-S 18-55mm - EF-S 55-250mm - EF 50mm 1.8 - EF-S 10-22mm - 100mm 2.8 Macro - EF 200mm 2.8L II
Photofun42
Joined Jun 2010
Oct 19, 2010 06:52 |  #5
Well I can see this forum has A==holes great advice.
neilwood32
Oct 19, 2010 07:00 |  #6
Unfortunately when you post such little information, people will tend to jump on it.
Can you tell us what kind of shoot, location, time of day, lighting rig (if any), subject etc? It helps folk advise properly (and keeps the jokers away)
Having a camera makes you no more a photographer than having a hammer and some nails makes you a carpenter - Claude Adams
Keep calm and carry a camera!
Gatorboy
Oct 19, 2010 07:12 |  #7
Have you done it inside? If so, do the same outside.
Dave Hoffmann
Hannya
Oct 19, 2010 07:15 |  #8
I've done green screen in the studio, but I'd imagine outside you'd have to deal with the background flapping around in the wind, changes in lighting (clouds etc) that might make the bg harder to remove later. If you are doing this because you want to cut out the subject and insert another background later, perhaps there are other ways of achieving this?
“Your first 10,000 photographs are your worst.” ― Henri Cartier-Bresson
Sports Pics (external link)
egraphdesign
Joined Jun 2010
Oct 19, 2010 07:27 |  #9
I have tried inside and out with out much success with people as the subject.
the problems I had were.
even lighting
background not smooth
and not having enough distance from subject from background
At the time I did not have strobes and by the time I got proper lighting I had lost interest in the project.
At the time the subject was my daughter and she has frizzy hair and I decided that even if I got it all correct her hair would never come out right.
Photofun42
Joined Jun 2010
Oct 19, 2010 10:59 |  #10
Thanks everone I tend to get upset seems like over things that are my fault so I will try again. I would really like to be able to take photos of cars ,motorcycles and put them in A different setting and the green screen seemed to me would work. I am new at all of this so please bear with me. Thanks Bill Goodwin
Rivest
Oct 19, 2010 11:12 |  #11
Photofun42 wrote in post #11125598 (external link)
Being new and telling this forum has A==Holes isn't the best way to make friends. Neither your title or your first post contained any useful information to give you some advice. No need to say those who replied are A==Holes.
Now that we have some more info, I can help. I'd suggest you take the cars/motorcycle you want to shoot in a garage. That way you'll control the lightning to your taste. Working with a green screen outside is way harder than doing it inside. I'd start inside than make my way outside when I feel my results are satisfying and the garage is limiting my photography.
Hi, I'm David.
Photofun42
Joined Jun 2010
Oct 19, 2010 12:18 |  #12
Thanks for the reply Rivest and maby you are right although had I read the question I do believe I would have been smart enough to understand what was asked for.
Rivest
Oct 19, 2010 13:27 |  #13
Photofun42 wrote in post #11125961 (external link)
Probably because you knew what you were looking for. The more precise you will be in your questions, the more accurate answer you'll get.
Hi, I'm David.
Scatterbrained
Gallery: 267 photos
Best ofs: 12
Oct 19, 2010 13:40 |  #14
Have you looked into a large collapsible chroma background? Maybe some chromakey paint and wall boards; it would be a pain to lug large boards around though. . . Lastolite makes some larger collapsible chromakey backgrounds that work like the collapsible reflectors/diffusers.
You could always set the background up against the wall.
You could also look into Onone's Mask Pro 4 software. It will add time to your post processing but will allow you to extract the subject cleanly.
500px (external link)
1x (external link)
instagram (external link)
ajaffe
Oct 19, 2010 17:16 |  #15
Thereee we go. The only way that I could see you doing something so large is by using a frame of some sort and hoping that there is little to no wind. You could set up behind some natural wind breaks like trees or behind a wall and such, but it will still be your biggest enemy with what is essentially going to be a green sail. Normally to combat this you could place holes for the wind to travel through but they would have to be placed rather strategically so they are out of frame.
Is there a particular reason you want to do it outside as opposed to inside?
www.jaffe.photo
3,082 views & 0 likes for this thread, 14 members have posted to it.
green screen
1056 guests, 104 members online
