I am looking for a one lens solution for hiking and Travel. It will pair with my 7D for landscape, portrait, group, cityscape, walkaround and animal(maybe). I have 580EXII when there is not enough light. Samples are absoultely helpful.
Thanks.
nonick Goldmember 1,588 posts Joined Jun 2009 Location: NYC More info | Oct 19, 2010 21:15 | #1 I am looking for a one lens solution for hiking and Travel. It will pair with my 7D for landscape, portrait, group, cityscape, walkaround and animal(maybe). I have 580EXII when there is not enough light. Samples are absoultely helpful. Gear|Searching for 7DII, Buying 5DIII 35L II, 24-70 2.8L IS
plasticmotif Goldmember 3,174 posts Likes: 2 Joined Sep 2008 Location: Tennessee More info | Oct 19, 2010 21:20 | #2 canon 17-55 IS or 15-85 IS Mac P.
LiberationFrequency Goldmember 1,334 posts Joined Jun 2010 Location: Montreal, QC More info | Oct 19, 2010 21:21 | #3 17-55 IS
JWright Planes, trains and ham radio... 18,399 posts Likes: 35 Joined Dec 2004 More info | I think if you go with a single lens that is 55 or 85mm at the long end, you're going to be limiting yourself. You may come upon a situation where you need more reach. If you want to stick with a single lens then I would suggest either a 28-135 or 70-200. Unfortunately you're going to have to sacrifice the short end. John
LiberationFrequency Goldmember 1,334 posts Joined Jun 2010 Location: Montreal, QC More info | Oct 19, 2010 21:37 | #5 Well the real question would be... are you hunting stuff or do you want landscape?
Oct 19, 2010 21:49 | #6 I have 17-55. That's not the ideal solution as it is lack of long reach. And it's not that wide when it comes to landscape. Looks like 15-85 is interesting. Thanks for mentioning it. I will give it a look. Gear|Searching for 7DII, Buying 5DIII 35L II, 24-70 2.8L IS
Oct 19, 2010 21:51 | #7 LiberationFrequency wrote in post #11128931 17-55 IS 35mm if you like primes But if you want a one lens fits all solution, the zoom is really the better choice. Thanks I have 17-55 already. Not an ideal solution for me. While I have no problem to use 35mm on 7D all day ( I used sigma 30mm 1.4 before) it's sure not a good solution for travel. I don't need fast lens as I am prety sure I will bring my flash. Thanks for your input. Gear|Searching for 7DII, Buying 5DIII 35L II, 24-70 2.8L IS
DeaconG Goldmember 1,474 posts Joined Mar 2009 Location: Port St. John, FL More info | Oct 19, 2010 21:55 | #8 There's always the "ultimate superzoom", the 28-300 3.5-5.6 IS L...but it's a handful... Gripped 5D Mark II & 50D|70-200 2.8 IS L|24-105 L|17-55|10-22|28 1.8|Σ 150-500|Σ 120-300 EX DG|Σ 50 1.4 EX|Σ APO 2X TC|580EXII|various other bits and pieces
Oct 19, 2010 21:56 | #9 JWright wrote in post #11129018 I think if you go with a single lens that is 55 or 85mm at the long end, you're going to be limiting yourself. You may come upon a situation where you need more reach. If you want to stick with a single lens then I would suggest either a 28-135 or 70-200. Unfortunately you're going to have to sacrifice the short end. Another alternative is a "superzoom" like Tamron's 28-300 I would suggest at least two lenses. I'm headed east next week and I plan on taking at least three lenses and two bodies with me. I'll probably have a 70-200, 28-75 and 14mm lenses, in addition to a 1.4X and 2X that will fit the 70-200. Thanks for your suggestion. I have 70-200mm 2.8L IS Mark II. While I have no problem to bring it for hiking, i would be more than happy not to. Most of the shots I took for landscape were from the shorter focal length tho. Not saying the long end is not useful, it is very useful and I use it for landscape too but I just tend to use the short end more in that situation. Gear|Searching for 7DII, Buying 5DIII 35L II, 24-70 2.8L IS
HyperYagami Goldmember 2,405 posts Joined Nov 2007 Location: Poughkeepsie, NY, USA More info | tamron 18-270mm.
Oct 19, 2010 22:00 | #11 LiberationFrequency wrote in post #11129023 Well the real question would be... are you hunting stuff or do you want landscape? I hope I can have 1 lens to do both. But if I have to choose, I would choose landscape before hunting. But I don't want a lens with slow AF that will hunt a lot in less than ideal lighting condition. Gear|Searching for 7DII, Buying 5DIII 35L II, 24-70 2.8L IS
Oct 19, 2010 22:04 | #12 DeaconG wrote in post #11129106 There's always the "ultimate superzoom", the 28-300 3.5-5.6 IS L...but it's a handful... I have gave that a thought but it's price and pull-push style hold me off (I had 100-400L before). Also one of my goals to go for one lens solution is to reduce the weight when traveling/hiking. So, that super zoom L will work agianst that goal. Thanks for your input anyway. Gear|Searching for 7DII, Buying 5DIII 35L II, 24-70 2.8L IS
Oct 19, 2010 22:07 | #13 HyperYagami wrote in post #11129120 tamron 18-270mm. http://www.dpreview.com …_3p5-6p3_vc_n15/page4.asp I had the non VC version on my Alpha mount before. I bought used at 180 dollars. And i really don't think the VC version worth 600 dollars. But thank you for input. I might still give it a look. Gear|Searching for 7DII, Buying 5DIII 35L II, 24-70 2.8L IS
DeaconG Goldmember 1,474 posts Joined Mar 2009 Location: Port St. John, FL More info | Oct 19, 2010 22:13 | #14 nonick wrote in post #11129159 I have gave that a thought but it's price and pull-push style hold me off (I had 100-400L before). Also one of my goals to go for one lens solution is to reduce the weight when traveling/hiking. So, that super zoom L will work agianst that goal. Thanks for your input anyway. Looks like you're running out of options quick! I assume the 70-300 L isn't gonna work for you either since you have a 70-200... Gripped 5D Mark II & 50D|70-200 2.8 IS L|24-105 L|17-55|10-22|28 1.8|Σ 150-500|Σ 120-300 EX DG|Σ 50 1.4 EX|Σ APO 2X TC|580EXII|various other bits and pieces
jantzer Senior Member 318 posts Joined Mar 2010 More info | Oct 19, 2010 22:28 | #15 15-85 is probably best on crop if you like to take landscape shots. I tried to use a 17-50 for hiking and found it no where near wide enough for landscape. You need an ultra-wide for that. Are you space limited or worried about the weight? You could always do a 10-22 and 55-250, which would still be light. Gear: 5D2, S95, Tamron 28-75, 35L, 135L
| Latest registered member is zachary24 1389 guests, 119 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
