Thread started 19 Oct 2010 (Tuesday) 23:13
Remotes
slimenta
Oct 19, 2010 23:13 |  #1
Tonight I shot a college soccer game. I set up a remote behind the goal, 7D with a wide angle lens, battery pack on the 7D. Pocket Wizard Multimax on the 7D and the transmit PW on the hot shoe of my 1D Mark IV. I was within 60 feet of the 7D and most of my triggering was not effective. I tested everything prior to beginning and it worked fine. Any thoughts?
www.stevenlimentanipho​tography.com (external link)
http://www.sportsshoot​er.com/members.html?id​=8865 (external link)
1DX x 2, 1D Mark IV X 4, 5D Mark III x 3, 200-400, 4.0, 400 2.8 (II), 300 2.8, 200 2.0, 70-200 2.8 (II),135 2.0, 85, 1.2, 50 1.2, 24 1.4, 17-55 2.8, 24-70 2.8, 16-35 2.8, 28-300 3.5-5.6, 100-400 4.5-5.6, 16-35, 2.8, 8-15, 4.0 fisheye, 1.4 X and 2X TC
chris270
Oct 20, 2010 08:22 |  #2
I have found the same thing with my PW II's. I had to get reasonably close for it to fire. I was using a Mark III 1D and the remote was a 40D. I had the PW on top of the remote camera and I read that if it is close to the ground it does not transmit well. I tried putting a 5 ft stake in the ground and hung the pw from that but with similar results. I know that the 40D obviously won't fire at the same rate as the 1D but it is barely firing the remote at all. Would love to find the answer to the OP's question too.
Christopher Cecere
My Website (external link) | My Blog (external link)
MaxPreps Galleries (external link) | Sportshooter (external link)
ZXDrew
Oct 20, 2010 08:38 |  #3
Did you set your lens to manual focus? Also try holding the shutter at half press a little longer. I found that when using a faster camera (40D in my case) to a slower (20D) it made a difference. Were all the batteries fresh?
PhotoWolfe.com (external link)
Facebook.com/PhotoWolfe (external link)
Gear / My flickr (external link)
slimenta
Oct 20, 2010 22:37 as a reply to  @ ZXDrew's post |  #4
I was on manual focus, had fresh batteries. The camera with the transmitting PW was shooting frequently with changing focus, so half pressing was frequent.
gromeo
Oct 20, 2010 22:51 |  #5
Did you use a pre trigger cable? The pre trigger cable will keep the cam from falling asleep. Also I have found that if I use the MultiMax as the transmitter and have the PWII as receiver I had better luck when it came to longer distances.
Nikon D4 and 60 2.8D Micro, 24-70 2.8G, 70-200 2.8G VRII, 200-400 VRII, SB800, SB600, Pocket Wizards, 4x WL-1600, Quantum Turbo 2x2, Sekonic 358 meter, TT AS, Takeoff, Belt System
http://rguzmanphoto.ph​otoshelter.com/ (external link)
http://www.romeoguzman​photography.com (external link)
http://www.sportsshoot​er.com/rguzman (external link)
cecilc
Joined Mar 2004
Oct 21, 2010 06:44 |  #6
gromeo wrote in post #11135944 (external link)
Agreed on the comment about the pre-trigger cable ....
Also, these two things to keep in mind:
- It's best if the antennaes on both pocket wizards are in the same orientation
- It's also best if you maintain line-of-sight between the transmitter and receiver
With my pre-trigger cable and minding the other two suggestions, my pocket wizards usually work pretty well .....
Cecil
Maxpreps Galleries (external link)
chris270
Oct 21, 2010 07:13 as a reply to  @ cecilc's post |  #7
I use a pre-trigger cable and always within LOS...I also have the auto-power off on the 40D turned off.
Christopher Cecere
slimenta
Oct 21, 2010 18:43 as a reply to  @ chris270's post |  #8
Could you guys explain the pre-trogger cable to me?
gromeo
Oct 22, 2010 13:48 |  #9
Pre trigger cable keeps the camera awake as if you were pressing shutter button down half way, this will keep the camera ready to fire as soon as it receives the signal from the PW
http://www.flashzebra.​com/shutter_pw/0090.sh​tml (external link)
1,190 views & 0 likes for this thread, 5 members have posted to it.
Remotes
774 guests, 149 members online
