Thread started 20 Oct 2010 (Wednesday) 07:58
M42 screw lens adapter, autofocus confirmation
uOpt
Oct 20, 2010 07:58 |  #1
I have a 135mm L/2.8 lens with a screw mount and a passive M42 to EOS adapter. Works great, except for the focusing challenge of course. I have the beep off anyway and I could just put the lens on and shoot with no setting changes (on my 40D).
If I get a M42 adapter with the focus chip, does that just make it beep with confirmation regardless, or does it only beep when there is actual focus? If the latter, how accurate is it?
My imagine composition sucks. I need a heavier lens.
richardfox
Oct 20, 2010 08:28 |  #2
The chipped adapters will beep the camera when in focus. I have one on my 500mm f/8 reflex lens, and it's quite accurate.
Canon 50D gripped, EF 50/1.8, EF-S 10-22, 17-40L, 24-105L, 70-200 f/2.8L, 100/2.8 macro, 100-400L, 300 2.8L, Canon 500 f8 mirror with chipped EF mount, 580EX, 1.4x and 2x Canon teleconverters, Canon EF Life-Size converter.
ctham
Oct 20, 2010 08:34 |  #3
You might also consider an Ef-S screen to help you with the manual focus. Along with the AF confirmation beep, you should also see the plane of focus a lot better with the Ef-S screen.
CaKe! (external link) | Flickr (external link) | Blog (external link) | Gear List
WhyFi
Gallery: 246 photos
Location: I got a castle in Brooklyn, that's where I dwell.
Oct 20, 2010 08:41 |  #4
Speaking from 5D usage - if you have the beep off, you have the beep off - only the focus point confirmation light will blip when you're in the focus range and (for me) only when you have the focus button depressed. As for the accuracy... I only have a 50/1.4 to go by, and... well, let's just say that it lets me know that I'm in the right neighborhood. YMMV.
Bill is my name - I'm the most wanted man on my island, except I'm not on my island, of course. More's the pity.
uOpt
Oct 20, 2010 08:42 |  #5
ctham wrote in post #11131198 (external link)
This goes on the viewfinder?
ctham
Oct 20, 2010 08:50 |  #6
The focusing screen is a separate thing, but it makes the plane of focus clearer in your viewfinder: https://photography-on-the.net/forum/showthre​ad.php?t=417029
newworld666
Oct 20, 2010 12:09 |  #7
I use very often a Zuiko 500mm F8 .. of course manual focus ..
And I don't imagine tu use an MF lens for action without AF confirm chip Euro TTL...
An then it' becomes really comfortable to use a MF lens for sport action ..
Just some samples
even in really dark conditions at 6400 isos with an F8 lens
IMAGE: http://photos.corbi.eu/Travel/2010-09-Japon-Naoko/IMG6210/1013036022_3gWse-X2.jpg
IMAGE LINK: http://photos.corbi.eu …10/1013036022_3​gWse-O.jpg  (external link)
IMAGE: http://photos.corbi.eu/Travel/2010-09-Japon-Naoko/IMG6179/1013033183_xeMLh-X2.jpg
IMAGE LINK: http://photos.corbi.eu …79/1013033183_x​eMLh-O.jpg  (external link)
For birds, once you are pre focus, the AF chip help you to follow the birds flight quite easily
IMAGE: http://photos.corbi.eu/Travel/Japon-2010/Animals/IMG8537/1051056701_sXKQE-X2.jpg
IMAGE LINK: http://photos.corbi.eu …37/1051056701_s​XKQE-O.jpg  (external link)
IMAGE: http://photos.corbi.eu/Travel/Japon-2010/Animals/IMG9498/1051057688_iKQFY-X2.jpg
IMAGE LINK: http://photos.corbi.eu …98/1051057688_i​KQFY-O.jpg  (external link)
IMAGE: http://photos.corbi.eu/Travel/Japon-2010/Animals/IMG8709/1051057083_hjcQ5-X2.jpg
IMAGE LINK: http://photos.corbi.eu …09/1051057083_h​jcQ5-O.jpg  (external link)
even erratic running little child ..
IMAGE: http://photos.corbi.eu/Travel/Japon-2010/Candids/IMG8857/1037848150_raojb-X2.jpg
IMAGE LINK: http://photos.corbi.eu …57/1037848150_r​aojb-O.jpg  (external link)
Even with elder people, it's interesting to point and shoot even with a 500mm.. which at F8 is a much bigger challenge than a 135F2.8 to fix focus
IMAGE: http://photos.corbi.eu/Travel/Japon-2010/Candids/IMG9043/1037852333_5maWa-X2.jpg
IMAGE LINK: http://photos.corbi.eu …43/1037852333_5​maWa-O.jpg  (external link)
So I would warmly recommend 4th gen AF confirm chip, they are really accurate and reliable (more than 90% good focus)
Marc
5DMKII+1Dx 24L1.4II 85L1.2II 180L3.5 300F2.8nonIS TC2XII ..... Sigma14F2.8AFDG, Zuiko 500F/8 Reflex
http://myc-photos.eu (external link)
uOpt
Oct 20, 2010 12:12 |  #8
I just ordered a new generation ring from ebay.
And now for the lens buying madness ... :D :D :D
donaldjl
Oct 24, 2010 09:58 as a reply to  @ uOpt's post |  #9
I've been interested in using a couple of my father's M42 lenses, and have a question regarding the adapters with confirmation chip.
You mentioned the 4th generation adapter. How do you know an adapter is "new" or what generation it is?
For example there were two M42 EOS adapters with confirmation chips on Fleabay this morning. One for $16, the other for $40. How do you know which is which? Price may not be an indicator of which generation the adapter is.
"And when he came to the place where the Wild Things are they roared their terrible roars and gnashed their terrible teeth and rolled their terrible eyes and showed their terrible claws..."
newworld666
Oct 24, 2010 10:59 |  #10
The main feature concerned with 4th gen chip is
"Another new feature is the "hard" blocking of shutter release until you get the confirmation signal. If you hold the shutter release when fully depressed, the shot will be taken immediately when you get the AF confirmation signal. This allows taking fast-moving subjects. "
You will probably have to buy a single chip and glue it to an M42 adapter
Already former programmable chip are mostly accurate to perform near to perfect AF confirm.
Marc
donaldjl
Oct 24, 2010 11:33 as a reply to  @ newworld666's post |  #11
Many thanks for sharing your knowledge on these.
I see what you're referring to. That's a very interesting technology to incorporate into the adapter. I've noticed a couple that are describing programming the focal length, maximum aperture, and lens focus micro-adjustment as well. It appears that the technology has really advanced since the early aluminum screw adapters.
Would using a new generation adapter still be compatible with a split focus screen, or does the new focus confirmation chips render the split focus redundant?
newworld666
Oct 24, 2010 11:45 as a reply to  @ donaldjl's post |  #12
I have no idea about the impact of the focus screen technology ..
I use an Af confirm chip with EG-S and EG-D without any trouble
Marc
WhyFi
Gallery: 246 photos
Oct 24, 2010 15:49 |  #13
The programability of the chip, FL and max aperture, doesn't really do much other than help you differentiate your lenses - it doesn't keep report an accurate f-stop for each shot.
Focus screen will not interfere with AF confirm chip functionality, or visa versa. Also, the AF confirm adapters that I've used, while admittedly inexpensive, haven't been able to lock in low light (ISO1600, f/2, 1/50) situations, so I've got a split screen on the way.
newworld666
Oct 25, 2010 04:08 |  #14
WhyFi wrote in post #11156566 (external link)
That's wrong in my case, I could lock 90% of the cases even at 6400 iso with a mirror lens at F8 for action or moving subjects
500mm F8 6400Iso 1/320
IMAGE: http://photos.corbi.eu/Travel/2010-09-Japon-Naoko/IMG6134/1013029921_wTVma-XL.jpg
IMAGE LINK: http://photos.corbi.eu …34/1013029921_w​TVma-O.jpg  (external link)
500mmF8 3200Isos 1/640
IMAGE: http://photos.corbi.eu/Travel/2010-09-Japon-Naoko/IMG5884/1012369657_3acud-XL.jpg
IMAGE LINK: http://photos.corbi.eu …84/1012369657_3​acud-O.jpg  (external link)
500mm F8 4000Isos 1/1000
IMAGE: http://photos.corbi.eu/Travel/2010-09-Japon-Naoko/IMG5951/1012368607_8GnmE-XL.jpg
IMAGE LINK: http://photos.corbi.eu …51/1012368607_8​GnmE-O.jpg  (external link)
IMAGE: http://photos.corbi.eu/Travel/2010-09-Japon-Naoko/IMG6210/1012367338_RLyCa-XL-1.jpg
IMAGE LINK: http://photos.corbi.eu …/1012367338_RLy​Ca-O-1.jpg  (external link)
500mm F8 3200iso 1/400
IMAGE: http://photos.corbi.eu/Travel/Japon-2010/Candids/IMG9065/1037852953_x6ebB-XL.jpg
IMAGE LINK: http://photos.corbi.eu …65/1037852953_x​6ebB-O.jpg  (external link)
Flying bird @ 2500iso 1/800..
IMAGE: http://photos.corbi.eu/Travel/Japon-2010/Animals/IMG8537/1051056701_sXKQE-XL.jpg
As you can see, even with a terrible AF body like a 5DMKII, it's working like a charm at very high isos ...
Based on my own experience, I would say, 3rd and 4th gen AF Confirm chip are really accurate and necessary for live candids or action with manual focus lenses ..
Marc
WhyFi
Gallery: 246 photos
Oct 25, 2010 05:55 |  #15
newworld666 wrote in post #11159608 (external link)
That's fantastic for you, but exactly why I prefaced my statement with, "in my case," and "admittedly inexpensive," (although they are supposedly, 'new generation' AF chips) no need to post the same images again and again and again.
6,751 views & 0 likes for this thread, 7 members have posted to it.
Latest registered member is EBiffany
1592 guests, 97 members online
