Thread started 27 Aug 2005 (Saturday) 23:46
Filter kept my lens from breaking
judyg
Aug 27, 2005 23:46 |  #1
I always use either a UV filter or no filter and the lens hood, depending. Today I had the filter and no hood on my 28-135 IS lens.
I dropped the camera on the ground, lens first. The filter shattered and is sort of fused to the lens cap. The lens seems OK, although it has some broken glass on it from the filter. I'll send it to Canon for cleaning and it should be fine.
Here is the filter after the fall (taken with a different lens):
bolantej
Aug 28, 2005 22:16 |  #2
sweet!
Mark0159
I say stupid things all the time
Gallery: 45 photos
Joined Mar 2003
Aug 28, 2005 23:40 |  #3
that's good that the filter had taken most of the impact
I think this is a good reason as to always do the following, use a UV filter, see reason above and use a lens hood.
I had dropped my 28-135 and I am lucky that it dropped on the lens hood first :)
I wonder if it's a fault of the lens ? or something :lol:
Mark
https://www.flickr.com​/photos/52782633@N04 (external link)
Canon EOS 6D | Canon EF 24-105mm f/4L IS USM, EF 17-40mm f/4L USM, EF 50mm f/1.4 USM, EF 100mm f/2.8 Macro USM | Tamron SP 35mm F1.8 Di VC USD | Canon Speedlite 550EX -|- Film | Canon EOS 3 | Olympus OM2 | Zuiko 35mm f2
mjordan
Joined Apr 2002
Aug 29, 2005 00:36 |  #4
If you had had the lens hood on, you probably wouldn't even have broken that.
Mike
Hillsboro, OR
Canon 1DMKII and lots of "L"
http://www.sitnprettyp​hoto.com (external link)
Curtis ­ N
Master Flasher
Aug 29, 2005 02:45 |  #5
Depending on what? When can't you use a hood?
judyg
Aug 29, 2005 08:00 as a reply to  @ Curtis N's post |  #6
I was trying to not be noticed too much, and the hood from that lens is very noticable.
Believe me - lesson learned - I'll always use a lens hood from now on.
But I was still really glad at least the filter took the hit and not the lens. And really really glad I chose that lens and not the new 17-40L.
It could have been a whole lot worse.
jfrancho
Aug 29, 2005 08:20 |  #7
Wouldn't this convince you to use the hood all of the time? I don't think the filter saved anything, looks like the lens cap itself was what bore the brunt of the impact.
kalmo
Aug 29, 2005 08:25 as a reply to  @ Curtis N's post |  #8
Maybe when he is using a polarising filter?!:D Or when he needs complete darkness when taking fireworks shots?!:D K
Canon 5D mk3
70-200mm f2.8 L IS
24-70mm f2.8 L
Speedlite 580 EX II
Elinchrom Ranger RX AS with 2 A-Heads & Deep Octa
judyg
Aug 29, 2005 09:49 as a reply to  @ jfrancho's post |  #9
Yes.
judyg
Aug 29, 2005 09:49 as a reply to  @ kalmo's post |  #10
Ummmm.... she, thanks. :)
malla1962
Joined Jul 2004
Aug 29, 2005 11:17 as a reply to  @ judyg's post |  #11
I allways use the lens hood.
kalmo
Aug 29, 2005 11:25 as a reply to  @ judyg's post |  #12
oops...sorry..she.....:D
Canon 5D mk3
70-200mm f2.8 L IS
24-70mm f2.8 L
Speedlite 580 EX II
wareseeker
Joined Jun 2005
Aug 29, 2005 17:27 |  #13
Ohhhh!!! I cannot afford to drop it.
Jackal
Aug 29, 2005 18:56 |  #14
Is it really needed that you send it to Canon? I mean...can't you just brush off the glass? Unless the glass somehow got inside magically. Good to hear the lense is ok!
5D+BGE4 | 30D+BGE2 | Canon 24-70mm 2.8L | Canon 28mm 1.8 | Sigma 10-20mm |Canon 50mm 1.4 | 580EX | 420EX
grego
Aug 29, 2005 19:34 |  #15
Yes, its good to have a lens hood on, but when its turned the other way, the filter is just another set of protection. Always good to protect it as much as possible.
Go UCLA (external link)!! |Gear|http://gregburmann.com (external link)SportsShooter (external link)|Flickr (external link)|
2,016 views & 0 likes for this thread
Latest registered member is thecoldestday
913 guests, 208 members online
