Thread started 20 Oct 2010 (Wednesday) 13:14
Will I be disappointed with the Sigma 15-30mm f/3.5-4.5? (indoors)
uOpt
Oct 20, 2010 13:14 |  #1
I need a wider angle lens to accommodate my EF 28-135 on my 40D. I want to do some winter wonderland shooting when the weather gets, well, sucky. I browsed the lens photo archive section here and one lens that really stuck out for me was the Sigma 15-30mm f/3.5-4.5. I just like the pictures coming out of it.
However...
I find myself using the camera indoors without flash occasionally. I have a 580 EX but I have quite a few snapshots that were not worth mounting the flash or where I figured it isn't sanctioned. I wonder whether the f/3.5-4.5 is a problem here? Is this a usable indoor lens? Should I rather aim for a 30mm f/1.4?
My imagine composition sucks. I need a heavier lens.
egordon99
Oct 20, 2010 14:05 |  #2
You will struggle indoors with a f/3.5-4.5 lens.
The Sigma 30mm is more useable, but is not wide so I'm not sure why you're considering it for a "wide" lens.
Your best bet is the Tokina 11-16mm f/2.8. If f/2.8 is too slow, you need to open up your wallet and buy a full-frame body and something like the Canon 24mm f/1.4 (or a less expensive Sigma 20-24mm prime)
gonzogolf
dumb remark memorialized
Gallery: 559 photos
Oct 20, 2010 14:13 |  #3
Indoors covers a lot of ground, but I doubt you could make acceptable photos in the average home 3.5, let alone 4.5 without flash.
uOpt
Oct 20, 2010 14:55 |  #4
Hmmmm.
Maybe I should hold off on lens madness for now. I was thinking about the Canon loyalty program and pounce on a 5DII. That would help a lot with the low-light noise I get from the 40D and of course it's FF with more light and it would turn my 28-135 into an actual 28mm.
gonzogolf
Gallery: 559 photos
Oct 20, 2010 15:08 |  #5
uOpt wrote in post #11133355 (external link)
Hmmmm.
Sure you gain some lattitude with higher ISO's, but you are still stuck with a turkey of a lens for indoors. Even with my 5D, I couldnt get away with 3.5 inside. If you want to shoot inside without flash you are going to need both a high iso capable camera and fast glass. But honestly getting a flash and learning how to use it so that your photos dont look flashed is a better alternative.
uOpt
Oct 20, 2010 16:13 |  #6
gonzogolf wrote in post #11133420 (external link)
As I said, I have a 580 EX and use it. I started the thread because sometimes I can't or won't use use it. Given that I did not buy a lens yet it makes sense to double-check and possibly adjust plans before buying.
crn3371
Oct 20, 2010 17:14 |  #7
It's also a discontinued lens and may need rechipping to work on a current camera body, assuming that Sigma still does so.
1,572 views & 0 likes for this thread, 4 members have posted to it.
Latest registered member is EBiffany
1592 guests, 96 members online
