I sent a PM to Jerry, but my question was pretty vague. I'm sure others have experimented with this. I currently have the single bracket with a single speedlight. After a recent location shoot where I chose not to use the speedlight configuration (because it felt too limiting) and ended up hauling a lot of heavy gear all over the place, I'm considering another path for this type of location shoot.
I'm considering getting the double bracket and another speedlight. With the speedo-Eli adapter, I'd be able to use Elinchrom modifiers with the dual speedlight configuration, and I'm thinking the new 70cm DO would be awesome for this.
It's relatively easy to see how to do this in manual mode, adjusting the power levels of each speedlight and metering with my light meter. What I'm wondering is if ettl is possible in this configuration. I'd be using a MiniTT on camera and I currently just have one FlexTT5. I suspect it's not possible to have a single FlexTT5 control the two speedlights, but I figured it wouldn't hurt to ask what others are doing. I also have PWII's I can use, if that helps. Thanks.
