What are your opinons as to the better all around performer between the Drebel XT and Nikon D70s?I know the D70s is more expensive due to a better kit lens but i'm looking to purchase a new Dslr and am doing alot of research between the two.thanks
digitaldaddy Member 69 posts Joined Aug 2005 More info | Aug 28, 2005 19:04 | #1 What are your opinons as to the better all around performer between the Drebel XT and Nikon D70s?I know the D70s is more expensive due to a better kit lens but i'm looking to purchase a new Dslr and am doing alot of research between the two.thanks Canon 40D
ddelallata Goldmember 1,191 posts Joined May 2005 Location: Brownsville, Tx USA More info | Aug 28, 2005 19:17 | #2 digital daddy wrote: What are your opinons as to the better all around performer between the Drebel XT and Nikon D70s?I know the D70s is more expensive due to a better kit lens but i'm looking to purchase a new Dslr and am doing alot of research between the two.thanks
Dr. David de la Llata
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Aug 28, 2005 20:16 | #3 You're not going to get objective answers on a Canon photography forum. I'd suggest that like David said, ignore the kit lens, and price the XT with a lens like the Tamron 28-75 F2.8, or something that suits you better. Both are good cameras and will do the job, what you should look at are the availability and cost of OEM and third party lenses, flashes, batteries, etc, etc. The camera body's typically a small investment compared with the cost of the rest of the system, if you really get into photography. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
Belmondo Cream of the Crop 42,735 posts Likes: 15 Joined Jul 2003 Location: 92210 More info | The D70 will cause hair to grow on the palms of your hands. Your teeth will itch, and then there's the strange smell. I'm not short. I'm concentrated awesome!
thanks guys,If i get Drebel Xt body only,what do you suggest for a good walk around lens? Canon 40D
OregonRebel Senior Member 867 posts Likes: 3 Joined Jul 2005 Location: Currently in Germany. More info | Aug 28, 2005 21:10 | #6 17 - 85 IS. Brian N
Hellashot Goldmember 4,617 posts Likes: 2 Joined Sep 2004 Location: USA More info | Aug 28, 2005 22:08 | #7 Permanent banDepends on what your budget is. I think that 17-85 is $500-$600 or so. I've found the Sigma 24-135 f2.8-4.5 to be quite good and will give you a longer reach than the 85, but only a 38mm effective FOV at the widest, but does have wider appetures. You can get the Sigma for $300 or so. 5D, Drebel, EOS-3, K1000
grego Cream of the Crop 8,819 posts Likes: 2 Joined May 2005 Location: UCLA More info | Aug 29, 2005 05:55 | #8 Just get yourself the Tamron 24-75 f/2.8. You can defintely get around with that being your first lens. A great starter lens, and its very good quality. Go UCLA
kalmo Senior Member 318 posts Joined Aug 2005 Location: Sydney, Australia More info | Aug 29, 2005 08:15 | #9 Get the canon so you can join this fantastic forum Canon 5D mk3
condyk Africa's #1 Tour Guide 20,887 posts Likes: 22 Joined Mar 2005 Location: Birmingham, UK More info | Aug 29, 2005 08:30 | #10 Go into a shop and try both. Buy which you prefer in handling terms and according to budget. Canon and Nikon make some fine lenses and so do Tokina, Sigma and Tamron. You can pick and choose which you want for the money you have. They will both do a great job if you learn how to use your gear correctly. https://photography-on-the.net …/showthread.php?t=1203740
Matatazela Senior Member More info | Aug 29, 2005 08:33 | #11 I must agree that the D70 is well built. It is much bigger in the hands, although I have found the XT to be a fantastic buy. I really like the camera and would agree to go Body Only - the kit lens is a bit soft.
Andy_T Compensating for his small ... sensor 9,860 posts Likes: 5 Joined Jan 2003 Location: Hannover Germany More info | Aug 29, 2005 08:38 | #12 Unfortunately, the Tamron is 28-75/2.8. some cameras, some lenses,
| Latest registered member is Thunderstream 1863 guests, 108 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
