Thread started 22 Oct 2010 (Friday) 20:44
Mini-Review: 7D and 5DII Quick IQ Comparison
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Post edited over 6 years ago by TeamSpeed. (2 edits in all)
Oct 22, 2010 20:44 |  #1
We were having a very nice and heated debate over in the Poll over 7D Remorse? post, and I decided I would put this together into a new thread. Discussions welcome, I tried to do this correctly per requests from others. I did a high ISO review some time ago too.
(LEGEND: top or left is always 7D, bottom or right is 5D)
TeamSpeed wrote:
Okay, I used my daughter as an unwilling participant in a quick (wasn't so quick, at least not for her) test between the 7D and 5DII. I used my 70-200 2.8 and used the same settings on both, in exposure, picture style (portrait), both AWB, both center point w/expansion, and noise reduction (standard), I just changed the focal length to try to frame the same in each shot.
No post processing, direct results comparing the two. What I noticed are slight color and exposure differences though they were set the same. I used 1600, which the 5DII won't even break a sweat, but others seem to not like the noise on the 7D here, so it seemed to be a fair compromise.
You can see the DOF differences because of the longer FL on the 5D, which is neat, and also the smoother overall complexion of the 5DII. Probably the only 2 things that stand out to me anyways.
No post processing, first the overall scene, then crops...
thumbnail
Hosted photo: posted by TeamSpeed in
./showthread.php?p=111​47387&i=i107341593
forum: Canon Digital Cameras
thumbnail
./showthread.php?p=111​47387&i=i195626108
TeamSpeed wrote:
Now the same post processing action I usually use on my lower ISO shots, ran on both. Again the color/exposure differences seem to cause a bigger impact on auto-level? The 5DII seems truer to life though, I will say, even though I used the same settings on both.
thumbnail
./showthread.php?p=111​47392&i=i42439336
thumbnail
./showthread.php?p=111​47392&i=i99279727
kcbrown wrote:
Just for grins, can you perform the test with the 7D at ISO 640 and the 5Dmk2 at ISO 1600? You'll be able to equalize the depths of field, too, either by narrowing the 5Dmk2's aperture by 1.3 stops, or (if possible) by widening the 7D's by 1.3 stops, either of which should nicely equalize your shutter speeds. You won't even have to change your flash power between the two cameras with them set up that way.
I only ask because while I realize that the 5Dmk2 will perform better than the 7D at any given ISO, it does so by giving up some depth of field. Sometimes that's perfectly okay, but I'd like to see how the shots look when the photographic parameters are equalized that way. It'll give better insight into the inherent differences in the properties of the sensors.
TeamSpeed wrote:
Not sure I did this correctly KCBrown, the exif should be intact to see if I messed it up. I used ISO 1250, f2.8 on the 7D, then ISO 3200, f4.5 on the 5DII. Let me know if I didn't do this correctly. No post processing at all, RAW->JPG.
First the overall scene, just resized...
thumbnail
./showthread.php?p=111​47614&i=i66195021
thumbnail
./showthread.php?p=111​47614&i=i15323639
TeamSpeed wrote:
Now for the crops...
Later Observation: tonal graduations are better on the 5D, and I might have twitched a bit on that last shot, yielding a slightly less sharp 5D crop. They are very close compared to other test shots I have taken of this same subject.
thumbnail
./showthread.php?p=111​47617&i=i266500365
thumbnail
./showthread.php?p=111​47617&i=i251089846
kcbrown wrote:
Thanks. There is a slight difference.
First, the 7D shot does appear to have slightly more noise, but oddly enough in the resized shots it looks smoother. That's probably a combination of the slight brightness difference between the two and the JPEG compression. This comparison makes it clear that the 7D has been slightly "tuned" towards higher ISO performance at the expense of lower ISO performance, because if that weren't the case then the noise signatures should be nearly identical, if not favoring the 7D slightly.
artyman
Sleepless in Hampshire
Gallery: 17 photos
Oct 23, 2010 03:29 |  #2
Well too my eyes I can't honestly see much difference between the two. Perhaps instead of the the 7D versus 5d2 wars it would be better to just go out and shoot.
Ken
J_TULLAR
Oct 23, 2010 03:31 |  #3
artyman wrote in post #11149214 (external link)
I second that :cool:
Model Mayhem (external link)
damnit
Oct 23, 2010 04:51 |  #4
I personally think they are very different animals, and ideally I would like one of each for the different types of photography I would like to do, but whatever you have got, spending time enjoying shooting with it will do you far more good than arguing about it round here :D
Thanks for the comparisons ... and FWIW in all 7D shots I see some of what I see with my 50D shots, punchier and slightly harsher details and colours ... it might seem slight, but I see it a lot round here which is another reason why I would like a 5D II, to me it captures far more detail and subtleties than my crop sensor is able to.
I personally think the reason for choosing either of these cameras is quite obvious, but if you can't see it for yourself , then simply save yourself some money and get yourself the improved fps/AF etc of the a 7D ;)
Website & Galleries (external link)
GEAR
Tsmith
Formerly known as Bluedog_XT
Oct 23, 2010 06:39 |  #5
I know there are many members who have both cameras and some prefer the 5D MkII over the 7D when it comes to ISO results but from what I've seen around the web and your samples too TS ... I just don't see anything that sets the 5D MkII apart as really surpassing the 7D in this category.
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Oct 23, 2010 06:45 |  #6
When I did this test, the first thing that seem to stand out to me was more the tonal qualities of the 5D.
The 7D, when dialed in with lenses, pulls the details, I really haven't seen very much even in regards where supposedly the 5DII has a weaker AA filter. I run the same actions on both sets and get something like 98-99% of the same details. However the 5D image is less harsh (I think somebody said this) and has a smoother appearance.
I also like the added life to f2.8 zoom lenses that the 5D brings to the table in regards to DOF. I know the reason the DOF is different is because once you frame your image the same as the crop, you either have changed your distance and/or FL, and that causes the DOF difference, but still, it does give that little extra.
I just like doing these tests because I have long since lost count of how many say "the 5D IQ is dramatically better than the 7D", etc. It is certainly not dramatic, but there is a difference that many do enjoy, and rightly so. That being said about the 5D, the 7D is easily the most versatile of any crop camera Canon has made to date, barring the 1D series. :)
The 1Ds MKIV will be an amazing camera if Canon keeps up the improvements. It will be an exciting announcement I think.
umphotography
grabbing their Johnson
Gallery: 21 photos
Oct 23, 2010 06:50 as a reply to  @ TeamSpeed's post |  #7
awesome..lets see the PP action:eek:
Mike
www.umphotography.com (external link)
Facebook (external link)
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Oct 23, 2010 07:01 |  #8
lol, not much difference, a bit punchier. Here it is with a more creative crop too.
luigis
Oct 23, 2010 07:37 |  #9
You can't compare different format images unless you have the SAME DOF in both pictures. When you put both cameras at F2.8 the 7D has the advantage of a larger DOF, it's hard to know if a section of the photo is not sharp or just not in focus and thus you can't compare.
If you want to use your 7D at F2.8 ISO640 1/500 then put the 5DII at F4.5, 1/500 ISO1600 then you'll have the same DOF, same shutter speed,same diffraction levels and same noise level.
Test = FAIL
www.luisargerich.com (external link)
Landscape Photography & Astrophotography
My Awesome Gear List
TeamSpeed
01010100 01010011
Gallery: 116 photos
Joined May 2002
Oct 23, 2010 08:21 |  #10
luigis wrote in post #11149589 (external link)
Test = FAIL
Perhaps you need to relook at the 2nd set of images, somebody needs some coffee to get started this morning. There are two tests here, one that shows the difference between the 5D and 7D with the same FOV and same exposure settings, and one exactly what you said, equalizing the formats. It covers the two ways people compare the two formats. In both cases, comparing sharpness is still valid. Comment = FAIL :)
DetlevCM
Oct 23, 2010 08:38 |  #11
And this test clearly shows the 5D MK II to be better.... :D
(Read this post with the humour of a 5D MK II owner - there really doesn't seem to be any real difference if any)
5D MK II AF Satisfaction Poll | Reduced Kit List
A Basic Guide to Photographyexternal link | Websiteexternal link
Flickrexternal link | Artflakesexternal link | Blurbexternal link
bohdank
Oct 23, 2010 08:38 |  #12
7D more harsh... that be me that said that. I haven't done any side by side testing, and won't, but that was one of the first things that I noticed about the 7D. Actually it was the first thing. I can speculate it has to do with the higher noise levels at low/mid ISO than the 5DII and is what contributes to the appeareance of sharper tonal graduations. How it will affect my overall (dis)pleasure with my 7D is still to be determined. I am seriously looking forward to a 5DIII.
TS: Thanks for the all the time you have put into these posts.
droopy1592
Oct 23, 2010 08:49 |  #13
There is not much in it. To balance the poster with the negative comment that didn't even read the entire post, thanks for going out of your way to do the work!
| Canon 7D| Canon 5D|Canon EF 70-200mm f/2.8L IS II USM | Canon EF-S 17-55mm f/2.8 IS| Canon EF 50mm f/1.4 | Canon EF 85mm f/1.2L II |
my photos on flickr (external link)
Ziffle
Oct 23, 2010 08:50 |  #14
Nice work Teamspeed.
It would be cool to see a sample of say a 20x16 print between the 2 cameras.
Now that the initial dust has settled from the 7D's release.... we can get back to creating great images with what ever camera you have.
I am another shooter waiting for the 5Dmkiii.
but this does not mean i am sitting on the side lines .... nope.
(....Just some random thoughts)
Wedding Photog's rule ........... just not sure what???
Gear List ~ VIAweddingPhoto(DOT)co​m (external link)
Destractions
Joined Jun 2010
Oct 23, 2010 09:04 |  #15
Wow, I thought there was supposed to be some appreciable difference between FF and a crop when it came to portraits. I'm having a pretty hard time seeing what the big deal is when it comes down to the final image.
The unholy trinity:
EF 70-200mm F4 \ & Tamron-F 2X TC
EFS 17-55mm f/2.8
EFS 10-22mm
27,202 views & 0 likes for this thread, 39 members have posted to it and it is followed by 2 members.
1460 guests, 137 members online
