Thread started 29 Aug 2005 (Monday) 06:56
Could not figure out how to get this shot
Debian ­ Dog
Aug 29, 2005 06:56 |  #1
I tried a bunch of different things last night (Rebel XT standard lens) to take a picture of my daughter in the dark, with just a 22" computer flat screen illuminating her. Since it was a "pretty" white desktop there was plenty of light but... no luck... always too little or too much light.
What camera settings would you have started with?
Rebel XT - Tamron 28-75 XR DI- Canon 420EX Speedlite w/ LightSphere II
Andy_T
Joined Jan 2003
Aug 29, 2005 07:32 |  #2
DebianDog,
welcome to the forum!
You might post one of your results with EXIF information.
It's a bit hard to tell with the information you have given us.
I assume that metering would have been a bit tricky - definitely not a 'green box' situation.
Best regards,
Andy
some cameras, some lenses,
and still a lot of things to learn...
(so post processing examples on my images are welcome :D)
If you like the forum, vote for it where it really counts!
CLICK here for the EOS FAQ
CLICK here for the Post Processing FAQ
CLICK here to understand a bit more about BOKEH
Debian ­ Dog
Aug 29, 2005 09:11 as a reply to  @ Andy_T's post |  #3
Andythaler wrote:
DebianDog,
Thanks and will do. Umm guess I have more reading to do. Green box?
Edit: OH the green box (snapshot mode) got it!
Andy_T
Joined Jan 2003
Aug 29, 2005 09:28 |  #4
My approach would be to use the camera metering (e.g. in A or P mode) as starting point, and experiment with over- or underexposing.
Also, maybe putting the camera on a tripod might be a good idea.
Finally, the 75$ 50/1.8 lens will be a great help in getting this kind of shots.
Best regards,
Andy
zacker
Joined Jan 2005
Aug 29, 2005 11:47 |  #5
how about raising the iso to 800? or a slowwww shutter speed?
-zacker-
http://www.theanimalha​ven.com (external link)
My Facebook, Friend me If you want!http://www.facebook.co​m/brokenfencephotograp​hy (external link)
http://www.facebook.co​m/theanimalhaven?ref=t​s (external link)
Debian ­ Dog
Aug 29, 2005 13:33 |  #6
I tried a very slow shutter speed but without a tripod you can guess the outcome ;) I may play with the bulb mode just for fun. The cost of film is right! :P
I think your on to something with a Ap mode and higher ISO.
Mitcon
Joined Jun 2005
Aug 29, 2005 13:58 as a reply to  @ Debian Dog's post |  #7
I second what Andy has said, and a tripod is a must with low light/slow shutter speeds. Don't shy away from bumping the ISO as high as needed either. If the light is too low and you can't get good focus, flick it to manual. As you said, the cost of the film in a DSLR is right lol. So don't be afraid to play with things and try different settings.
Cheers Wayne :D
EOS 30D+350Dx2+BG-E2+BG-E3+18-55MkII+EF 70-300IS/USM+EF 75-300IIusm+Sigma 50-500DG+Tamron SP90 f2.8Di+Sigma 17-70+Kenco MC7 2x+580EX+430EX
POTN Aussie club
Huckaback ­ Photo
Joined Jan 2005
Aug 29, 2005 15:03 |  #8
Debian Dog
A easy way is obviously to bracket your exposures by taking several test shots.
the other more positive route to take is to meter the amount of light falling on your subject rather than reflected off the subject.
obviously this requires a hand held exposure meter with invacone in place.
I use a Sony Trinitron... just checked this with a Gossen meter, set at 800 ISO it gave me 1/15 at F1.8 ( or 1/8th at f 2.8....or 1/4 at f4 ) I transfered the setting to my 1D Mk2 and was pleased with the result .
Most important here is my reading taken at 12" from the monitor, now move away to 30" and the fall off in light intensity is considerable.
Andy is spot on, the best lens would be 50mm f1.8 or f1.4.
I'm assuming the actual monitor screen is not in shot.
if you wanted the screen with detail .
you would probably need a shutter speed of 1/80 th to 1/100 th sec because of the scanning effect on monitors & TV's. this is not an exact science, more often trial and error, but at least digital helps .
Best of luck
Martin (Huckaback Photo)
PS. a reflector just out of shot would help put a bit of detail in the shaddow side of the face.
Old photographers never die. They just go out of focus
1,728 views & 0 likes for this thread, 5 members have posted to it.
1863 guests, 108 members online
