Thread started 25 Oct 2010 (Monday) 20:40
Figure on the beach C&C Pls
bpiper7
that type of outlier
Gallery: 129 photos
Oct 25, 2010 20:40 |  #1
Does this work?
What might make iit better? Edit::: images incorporating some of the suggestions in post 14 of this thread.
IMAGE: http://bpiper7.zenfolio.com/img/s6/v5/p303303681-5.jpg
Bill
billpiperphotos.com (external link)
Gear: 60D - 400D - 15-85 EF-S, 55-250 EF-S,18-55mm EF-S, EF, 50mm 1.8 and more stuff .
circusofcrows
Oct 25, 2010 21:16 |  #2
Strong composition with the leading lines. Horizon isn't straight - fix that. If you've done anything in post, the contrast between the sky and water is lacking. Might be a good candidate for B&W.
Also, top left hand corner looks like you have some dust on your sensor.
Bodies: Canon 60D
Lenses: 17-40L f/4 | 50mm f/1.4
Gear: Kata 467i, Lowepro Slingshot 200AW
whydub
Oct 25, 2010 23:42 |  #3
I think you should try B/W for the picture. Great composition.
bpiper7
Gallery: 129 photos
Oct 26, 2010 09:39 |  #4
circusofcrows wrote in post #11164777 (external link)
whydub wrote in post #11165601 (external link)
<chuckle> You guys and your horizons. ;)
Okay two votes for B&W. Thanks I'll try it.
Any other cirtiques appreciated.
Bill
bone11
Oct 26, 2010 10:18 |  #5
Something looks off since the light source is clearly from the right yet the water and right side are all darker. I think the sky and water were burned a bit too much.
GorgeShooter
Oct 26, 2010 10:28 |  #6
Nice colors and the person really makes this shot. The horizon looks tilted and I think the rule of thirds would make this a better image (crop out some of the sky).
1DX | 5D MkII (gripped)
16-35 f/2.8L | 24-70 f/2.8L | 24-105 f/4L IS | 70-200 f/4L IS | 100-400 f/4.5-5.6L IS | 24 f/3.5L TS-E | 45 f/2.8 TS-E | 40 f/2.8 Pancake | 15 f/2.8 Fisheye | Tokina 100 f/2.8 Macro | Canon 1.4x TC | 580 EX II | 430 EX II | Manfrotto 055CXPRO4 | Kirk BH-1
:: Smugmug :: (external link) | :: Photography BLOG :: (external link) | :: Workshops and Classes (external link) ::
nilomis
Oct 26, 2010 10:39 |  #7
My 2c IMHO:
a) Adjust the horizon.
b) Crop a portion of the bottom part. This will put the person more close to the viewer.
In any case it's a very nice pic.
Cheers
swetsastonic
Oct 26, 2010 12:09 |  #8
you should have swept the beach clear of all footprints but the person's before taking the picture. there should also be a dolphin jumping out of the water in the distance.
kidding, of course. I really like this. it definitely established a mood. I agree that you should maybe look to crop the bottom, but not much, because you want the space to give the sense that they're alone, not just walking right in front of you. maybe below that first footprint or where the dried seafoam/seaweed kind of ends...
corkneyfonz
Oct 26, 2010 17:32 |  #9
Agree with both the crop and horizon comments, great potential.
My Flickr (external link)
TopHatMoments
Oct 26, 2010 19:10 |  #10
Tides going out. The ole time simply isn't going to walk into that directing with it coming in.
The shoreline is gonna have that bit of lower level as it is where the water rolls when the tide is in.
The water is a bit higher as the outgoing tide crashed into the surf coming in. The beach is at a slight grade as all beaches are.
I think maybe the foreground and the distance are at different levels and that make the beach look odd.
The light is coming from the right, shows on the ole timers windbreaker. Also the sun is very low in the sky maybe not to long before sunset if not already started. The water is darker as it is full of sand with the roll of the retreating tide. That makes the water tucked in a bit not allowing any on the light to hit it. The foam and the silt at the surface above the roll is not letting much light through. The sky well it's sunset.
I've been wrong before so if the dice turned up oops, so much for my guess.
Canon to PhotoShop, “Beam me up”! LR3 set course for CS5, Warp speed 64!___ ((dpp___/==***^***
karobinson
Oct 26, 2010 19:14 |  #11
My hat is of to you TopHatMoments.....well said my friend.
Ann Robinson:)
My Gear: bunch of stuff;....some I love ... some I hate ... some I can't live without..loving my 5d3...
TopHatMoments
Oct 27, 2010 09:47 |  #12
The OP does live on the east coast according to location info, in which case it could be an early morning shoot.
Ok I did a tinker on my iPad and uploaded with it also ( still learning to tame the pad around the way Steve saw fit for it's use )
IMAGE: http://farm5.static.flickr.com/4148/5120223495_6ff9a9f026.jpg
bpiper7
Gallery: 129 photos
Oct 27, 2010 16:02 |  #13
bone11 wrote in post #11167709 (external link)
That was my processing. There's kind of a raggedy vignette thing going on.
GorgeShooter wrote in post #11167752 (external link)
Thank you, Shooter. Yes, I understand that a crooked horizon upsets everyone but me. ;) But you're all right - it would be better straight.
nilomis wrote in post #11167803 (external link)
My 2c IMHO:
Cheers
Thanks much.
swetsastonic wrote in post #11168357 (external link)
I thought I did enough just wiping out the two people in the distance. ;)
Thanks for looking and the kind words.
corkneyfonz wrote in post #11170374 (external link)
Thank you. I think the vote is unanimous.
TopHatMoments wrote in post #11174241 (external link)
Thanks TopHat. I think your crop satisfies all the suggestions very well. And I'm going back to rework it from scratch and that's where I'll be aiming.
Thanks to everyone for their input.
Bill
bpiper7
Gallery: 129 photos
Oct 27, 2010 19:53 |  #14
Okay here goes. I tried to follow the good advice I got merged with my own vision. I wanted to keep the moody lighting. And the horizon was really pretty straight. The surf is high and those are swells in the upper right. Not the horizon. But.... I adjusted it a degree. :)
IMAGE: http://bpiper7.zenfolio.com/img/s10/v2/p443592938-4.jpg
I've not done much B&W and I THOUGHT I had a plug in but it's gone. So I messed with the channel mixer and some layer adjustments and came up with this. Have mercy.
IMAGE: http://bpiper7.zenfolio.com/img/s6/v5/p26567400-4.jpg
Bill
1,772 views & 0 likes for this thread, 10 members have posted to it.
2879 guests, 150 members online
