Thread started 26 Oct 2010 (Tuesday) 16:27
Pocket Wizard firmware update problem?
squaresnappr
Oct 26, 2010 16:27 |  #1
I hope somebody can help, I cannot update my mini tt1 and 2 flex tt5's to firmware 5.15. I get an error extracting from file 7. I tried reinstalling the pocket wizard utility. Btw, I am on a mac. I would like to update the firmware to 5.15 since they made improvement for my camera.
http://www.solofotogra​phy.com (external link)
http://www.modelmayhem​.com/1896508 (external link)
gromeo
Oct 26, 2010 16:31 |  #2
Make sure you are using the most recent PW Utility which is 1.18.9, I just did the update a couple of days ago with no problems, (using Mac).
Nikon D4 and 60 2.8D Micro, 24-70 2.8G, 70-200 2.8G VRII, 200-400 VRII, SB800, SB600, Pocket Wizards, 4x WL-1600, Quantum Turbo 2x2, Sekonic 358 meter, TT AS, Takeoff, Belt System
http://rguzmanphoto.ph​otoshelter.com/ (external link)
http://www.romeoguzman​photography.com (external link)
http://www.sportsshoot​er.com/rguzman (external link)
squaresnappr
Oct 26, 2010 16:52 |  #3
gromeo wrote in post #11169966 (external link)
Thanks for the reply, I did use the latest utility.
LBaldwin
Oct 26, 2010 18:10 |  #4
I had a little issue with this too, having just bought the radios. After you install the new software to the you computer make sure that you do a complete reboot on the computer. Not just a restart, but a cold restart. Then bring every thing back up per the instructions.
Les Baldwin
http://www.fotosfx.com (external link)
sdipirro
Oct 26, 2010 19:27 |  #5
I did the update from my Windows PC and didn't run into any problems.
Cameras: 1DX, 1D4, 20D, 10D, S90, G2
Lenses: Canon 10-22mm, 16-35mm f2.8L II, 24-70mm f2.8L, 70-200mm f2.8L IS, 300mm f2.8L IS, 200mm f2L IS, 50mm f1.4, 50mm f1.2L, 85mm f1.2L, 1.4x TC, 2x TC, 500D macro, Zeiss 21mm
Lighting: 580EX, Elinchrom 600 RX's, D-Lite 4's, ABR800, 74" Eli Octa, 100cm/70cm DOs, Photoflex Medium Octa and reflectors, PW's, Lastolite Hilite, Newton Di400CR bracket
LBaldwin
Oct 26, 2010 22:23 |  #6
If all else fails call them tomorrow, EST. I have already talked to them once and they took good care of me.
Les Baldwin
squaresnappr
Oct 27, 2010 16:34 |  #7
LBaldwin wrote in post #11170609 (external link)
Thanks but I reset the pram and now everything is installed. Thanks to everyone that replied.
3,073 views & 0 likes for this thread, 4 members have posted to it.
1025 guests, 107 members online
