Thread started 26 Oct 2010 (Tuesday) 17:16
7D Main Dial Issues
RazorbackSam
Oct 26, 2010 17:16 |  #1
My 7D ( I bought it in May?) is causing me some problems. Intermittently the Main Dial will become unresponsive. This prevents me from shooting in Manual mode, the auto modes still work because they don't rely on the Main Dial. Sometimes it will become responsive again after actuating the shutter, sometimes it requires a simple ON/OFF cycle. But there have been at least two times that nothing I did would fix it. Both of those times I turned the camera OFF and then sometime later (1-2 hours) turned it back ON to find that the Main Dial was working again. As you can imagine this is very frustrating.:(:(:cry::cry: Has anyone else suffered from this??
[Canon 7D | 24-70mm 2.8 L | 70-200mm 2.8 IS L | 18-135 3.5~5.6 IS | 28mm 1.8 | 50mm 1.8 | Manfrotto 055XPROB Legs - 222 Head | Manfrotto 060B MonoPod
www.settlephotos.com (external link)
nitehawk55
Joined Jun 2010
Oct 26, 2010 17:18 |  #2
Under warranty ?...send it in and have it checked out .
Mine is fine but you may have got one with a bad control , it happens .
patlannon
Oct 26, 2010 17:35 |  #3
I've never seen that problem, have you talked to Canon tech support about this problem yet? They may have a fix for that. Also, what version of firmware are you running in your camera?
Pat,
West Seneca, NY
Gear, 5D3, 7D, Glass, All Canon, 8-15mm L, EFs 15-85mm, EFs 60mm Macro, EF 100mm L Macro, EF 24-105mm L, EF100-400 L.
apersson850
Obviously it's a good thing
Gallery: 35 photos
Oct 26, 2010 17:42 as a reply to  @ patlannon's post |  #4
The main dial is used by all modes.
The quick dial is used to set exposure compensation in automatic modes and aperture or shutter speed (configurable) in manual mode.
The quick dial can be disabled with a lock switch below it.
The main dial may become unresponsive if you have a battery grip and happened to place the main dial on the grip in a position between two click stops.
Anders
RazorbackSam
Oct 26, 2010 20:15 |  #5
apersson850 wrote in post #11170460 (external link)
That is some very interesting information! Is that from experience or is that documented somewhere?
My 7D is gripped with a Canon grip, but I am pretty sure that some of the occurrences were before I added the grip. But the more difficult occurrences have been since I added the grip.
Too bad I left it with the local camera shop to see if they could replicate the problem. I'll be down there tomorrow to try that myself!
PaulMtl
Oct 26, 2010 20:35 |  #6
Still, none of this ever happened with a Canon grip on my 20D and 40D.
Out of curiosity, where is the 7D grip manufactured?
Canon 7D, grip, 430EX, 50 f/1.8, 17-40 F4 L, 24-105 F4 L, 70-200 F4L
www.pbase.com/pbielec (external link)
lannes
Oct 27, 2010 08:37 as a reply to  @ PaulMtl's post |  #7
+1 I've heard that when the input dial on the vertical grip is in between it's indents, it can disable the camera body main input dial.
apersson850
Gallery: 35 photos
Oct 27, 2010 09:29 as a reply to  @ lannes's post |  #8
You heard that in post #4 above, or elsewhere?
It doesn't matter, it's not a rumor. Anyone who has a grip can verify that for himself.
Anders
PaulMtl
Oct 27, 2010 10:02 |  #9
Now, I'm curious to try to reproduce the same issue on my 40D.
If it doesn't happen on the old grip, it means that they did screw up something in the new one.
lannes
Oct 27, 2010 10:31 |  #10
apersson850 wrote in post #11174122 (external link)
Sorry didn't see that, I saw it in another post on the forum someone was having a problem with a third party grip, it looks like that's not the reason for the op's problem as he did not respond to it.
apersson850
Gallery: 35 photos
Oct 27, 2010 12:28 as a reply to  @ lannes's post |  #11
It happens on my 40D, at least. It happens on every gripped Canon I have, actually.
Anders
PaulMtl
Oct 27, 2010 21:12 |  #12
I just tried with my 40D. Basically, it is not possible to get the grip's dial stuck between the clicks unless you hold it there with your fingers. In that case, the main dial can become unresponsive. But it not possible to stop between the clicks otherwise, the springs are too strong.
So, it seems like a mechanical problem with the new grip.
RazorbackSam
Oct 28, 2010 14:27 |  #13
I was able to reproduce the unresponsive main dial consistently by putting the grip dial in between clicks... it wasn't simple to get it there, but it would stay without any coercion once you got it in that position... at least now I have something to "check" when it happens again. thanks for everyone's help!
7,984 views & 0 likes for this thread, 6 members have posted to it.
7D Main Dial Issues
825 guests, 147 members online
