Thread started 29 Aug 2005 (Monday) 13:44
Raw Post Processing Blues
mdm
Aug 29, 2005 13:44 |  #1
I'll tell you how bad I am at post processing. I just finished loading about 15 pictures on the computer. I used RSE to adjust. When I was done I created the jpegs. My wife was passing by and said that it seems like I have dropped my camera because none of my pictures looked good any more. Really since I started shooting raw. It kinda took the wind out of my sails but I am determined to hang in there and learn raw post processing. Is there a guide, book, thread that will help me in the basics of post processing? Any tips, ideas, suggestions are welcome.
cosworth
I'm comfortable with my masculinity
Aug 29, 2005 13:50 |  #2
My lady uses my camera. I tell her to set auto levels (exposure, shadows etc), open the file then bump contrast +10 - then do a USM of 300 and .04.
She seems to do ok with those simple settings.
people will always try to stop you doing the right thing if it is unconventional
Full frame and some primes.
cfcRebel
Aug 29, 2005 14:53 |  #3
Same issue here. I have switched back and forth between JPEG and RAW many times i suck at PP. I'm still reading Chapter 1 in the PS CS tutorials. To make u feel better, i just learned how to remove red eyes using PS this past Saturday. :(
The PP learning curve is soooo deep for me, but i shall conquer it one day.
Fee
Canon | SIGMA | TAMRON | Kenko | Amvona
Desertraptor
Gallery: 212 photos
Aug 29, 2005 18:32 |  #4
Jpeg seems to have a lot more contrast I found which makes the colour more vivid so now when I shoot RAW in PP I ad a new layer for Brightness/Contrast, select vivd and adjust till I like it. Not always though
Peter
Canon 6D|60D|40D
Lens 10-22mm f2.8|50mm f 1.8|100mm f2.8 Macro
24-70mm f2.8|L100-400mm f4.5-5.6L
Flash 430EX II
Telescope Skywatcher 600mm ED80 f7.5 GEM EQ3
jfrancho
Aug 29, 2005 19:28 |  #5
Try this book out: http://www.amazon.com …v=glance&s=book​s&n=507846 (external link)
There is a version for PS CS as well, same author. This book really solidified my raw workflow.
mdm
Aug 29, 2005 21:48 |  #6
Thanks all. I like the white balance for raw and feel ok with that. I need to work on understanding the sharpening. Oh yea and everything else.
ssim
Joined Apr 2003
Aug 29, 2005 22:48 as a reply to  @ mdm's post |  #7
Learning the post processing of RAW images can sometimes be undaunting but in the end it will be well worth it. The real trick is to get your images exposed properly to begin with and then doing just a straight conversion without alot of tweaking. It is just a matter of practising. Don't give up.
FWIW, I very rarely ever use the sharpening in the RAW conversion. I always do this in photoshop as one of the last steps.
scottbergerphoto
Joined Jun 2003
Aug 30, 2005 07:42 as a reply to  @ ssim's post |  #8
Set your camera up as you would for jpeg with your usual parameters. Then shoot raw. If you select "settings as shot", you Raw conversions should be identical to your jpegs. Then you can go back and convert again(as many times as you want) adjusting different parameters. Usually the only thing I adjust in conversion is Exposure and White Balance. My camera settings are all Neutral(0).
One World, One Voice Against Terror,
Best Regards,
Scott
ScottBergerPhotography (external link)
Hellashot
Joined Sep 2004
Aug 30, 2005 11:55 as a reply to  @ cosworth's post |  #9
A USM of amount 300 and pixel radius of 0.04? That small a pixel radius won't do anything. I set sharpening to 0 during raw conversion and use amount 375 and pixel radius of 1 for ISO 100 images at 0 threshold.
5D, Drebel, EOS-3, K1000
lenses from 12mm-500mm
jfrancho
Aug 30, 2005 12:05 |  #10
The documentation (external link) that goes along with the TLR Sharpening Toolkit (external link) has an excellent explanation of how Unsharp Mask works.
cosworth
Aug 30, 2005 12:35 as a reply to  @ Hellashot's post |  #11
Maybe not on your pictures, but it works just enough for mine. It actually does something that my eyes see as pleasant.
Overly sharp pictures do not print that well (4x6) imho.
Scottes
Trigger Man - POTN Retired
Joined Nov 2003
Aug 30, 2005 15:30 as a reply to  @ Hellashot's post |  #12
Actually it can do quite a bit. You've obviously never tried it. Funny how one can form "knowledge" with no experience.
You can take my 100-400 L away when you pry it from my cold, dead fingers.
Scottes' Rum Pages - Rum Reviews And Info (external link)
Follower of Fidget - Joined the cult of HAMSTTR©
1,790 views & 0 likes for this thread, 9 members have posted to it.
968 guests, 101 members online
