Thread started 27 Oct 2010 (Wednesday) 17:04
Hoya Pro1D M-CPL
five0.4tluv
Oct 27, 2010 17:04 |  #1
I just put one on my 15-85 and did some test shots outside. While I'm looking through the viewfinder should I be able to definitively tell where the filter "is". I had my camera pointed at the sky and was rotating but could not tell where my polarization was. It has about 2/3 of the edge of the filter grooved so I assume that means something but what.
It appears from looking at the pics on the computer that the smooth portion is the CPL areas. Is that right?
40D
Feedback
https://photography-on-the.net …=12524713&postc​ount=27116
https://photography-on-the.net …=16216631&postc​ount=41043
five0.4tluv
Oct 27, 2010 20:42 |  #2
No one can help me on this?
40D
Feedback
argyle
Oct 27, 2010 21:11 as a reply to  @ five0.4tluv's post |  #3
You should notice the effects of the polarizer in the viewfinder as you rotate the filter. Of course, if the sun is directly behind you there won't a lot, if any, polarization to see. For best results, you need to be positioned 90-degrees to the sun (as you are looking through the VF, the sun needs to be in line with either of your shoulders). It also has other uses other than shooting the sky/clouds.
Also, a tip: when looking through the VF, rotate the CPL in the counterclockwise direction...this will prevent it from accidentally unscrewing and falling to the ground (or in the water if you happen to near it).
1,238 views & 0 likes for this thread
Hoya Pro1D M-CPL
Latest registered member is 360nomad
1152 guests, 237 members online
