Thread started 28 Oct 2010 (Thursday) 21:44
Lighten me up on HSS
Shamir
Oct 28, 2010 21:44 |  #1
Hi there POTN!!!!!!!!
I want to buy the PW mini system for using with my 2 Canons 430EXiis.
The only reason I'd like to do this is the HSS but im a bit confused..
Lets say i'm shooting at
F/9 ISO 100 1/160th in daylight and my Canon 430EXii is in an umbrella at 1/2 power..
If I open up my aperture to f/2.8 iso100 and 1/800 or 1/1000, Do I lower my flash power to 1/8th?! or 1/16th and still get the same flash -subject exposure!?
sorry, i'm just a bit confused as I've seen in many workshops talking about shutter speed controls ambient and aperture controls flash exposure.
Any hint, tip or anything :p?!
Shamir
My Website - Click Here (external link)
Wilt
Oct 28, 2010 21:55 |  #2
If you have a 430EXII under ETTL control of the body, you do nothing to alter power on the flash, the camera does all the work of issuing a command for how much light it wants. You use FEC to tell the camera to tell the flash to give less or more exposure than it otherwise might output.
Only if you put the flash on flash Manual output control (e.g. 1/1, 1/2, 1/4 power) then you select the appropriate power level (not the camera ETTL command to the flash)
If HSS has been turned on, then the body gives the approporiate command to the flash to output for HSS according to the shutter speed which was selected.
PacAce
Joined Feb 2003
Oct 28, 2010 22:07 |  #3
Shamir wrote in post #11185026 (external link)
With a shutter speed of 1/160, the flash would be working in "normal" mode. As soon as you set the shutter speed above the max sync speed of the camera, the flash will switch to HSS mode (assuming it has been enabled via the HSS switch). In HSS mode, the GN of the flash changes so that 1/2 power in HSS will no longer have the same brightness as 1/2 power in normal mode would. In other words, setting the flash to 1/8 or 1/16 power in HSS mode would decrease the flash intensity too much to provide the same flash illumination at f/2.8 as it did when set to 1/2 power at f/9. You would probably need to keep the flash at 1/2 power (or maybe even bump it up to between 1/2 and full power) if you set the shutter speed to 1/1000 since you lose about 2 stops switching to HSS mode and an additional stop for each stop above max sync speed you go.
...Leo
Shamir
Oct 29, 2010 13:06 |  #4
Thanks PacAce that was the answer I was looking for..
oh boy =/ and I thought it was THAT easy hahaha!
guess i'll stick with my Yongnuos for now!
Shamir
900 views & 0 likes for this thread
Latest registered member is markhilton
790 guests, 162 members online
