Thread started 28 Oct 2010 (Thursday) 23:11
Creative Light Hot Shoe Bracket
_method
Oct 28, 2010 23:11 |  #1
Was looking to get into the CL modifiers because I like their speedring for speedlights as well as for PCB stuff and then any other system I may upgrade to. My question is whether or not you can fit two speedlights on there, one regularly mounted and then one upside down on top, as opposed to side to side.
Thanks in advance.
-Matthew
MatthewBaltrusitis.com (external link)
_method
Oct 31, 2010 13:23 |  #2
No one?
DisrupTer911
Oct 31, 2010 22:49 |  #3
The CL bracket doesn't have 2 cold shoes.
And the ring isnt IMO large enough to fit to inside it. Maybe 2 flush with it but not in it.
www.vividemotionphotograph​y.comexternal link
bobbyz
Nov 01, 2010 08:38 |  #4
Can you put link to the intem at B&H? Then yoy might get better response.
Fuji XT-1, 18-55mm
_method
Nov 01, 2010 08:49 |  #5
http://www.bhphotovide​o.com …eedring_for_Por​table.html (external link)
I know that it does not have two cold shoes, what I am looking to do is put one in the cold shoe and then invert another and put it on top of the mounted one.
The ­ Loft ­ Studios
Nov 01, 2010 09:10 as a reply to  @ _method's post |  #6
Use this VIDEO (external link) as a reference and it could be done with some Ball Bungies.....
Or instead of purchasing a $100.oo item that holds one Speedlite, you could buy a standard Speedring and some Ball Bungies and you could mount 2-3 Speedlites and save a ton of cash.....
MARK
abbadon31
Gallery: 264 photos
Best ofs: 10
Nov 01, 2010 09:14 |  #7
You can mod it to hold 2 with some flat bar
I AM SHOM
DisrupTer911
Nov 01, 2010 14:09 |  #8
_method wrote in post #11203502 (external link)
wow $96 is a lot better then MPEX had them for at PhotoPlus @ $141.
bobbyz
Nov 01, 2010 14:37 |  #9
Thanks for putting the link. I just looked at the picture and it seems height of the flash is not adjustable. Now I don' thave this bracket and only used Photoflex brackets and the one which comes with QBox24 but I think you will have problems if using say flexTT5 or other RF triggers which go under the flash hot shoe. I could be wrong.
2nd for this kind of price, why not look at Kacey's bracket. Mine should be here in couple of days and I will update.
Fuji XT-1, 18-55mm
_method
Nov 01, 2010 15:05 |  #10
bobbyz wrote in post #11205471 (external link)
You're right I should look into the Kacey Bracket. Can it accept CL modifiers?
bobbyz
Nov 01, 2010 21:41 |  #11
_method wrote in post #11205667 (external link)
I don't have mine yet but it is suppose to work with different modifiers. Ask him.
Fuji XT-1, 18-55mm
J ­ Kacey
Nov 01, 2010 21:45 |  #12
The brackets with our softbox ring attached will accept any rod type box, strip or octa.
Kacey Enterprises (external link)
_method
Nov 02, 2010 00:03 |  #13
J Kacey wrote in post #11208075 (external link)
What does this joker know?
:p
Thanks for the response, saves me some Googling. I have seen you bracket before, might have to pick up both the dish and that bracket after I get another alien bee, very tempting.
Off topic, what grids will fit your BD?
2,030 views & 0 likes for this thread, 6 members have posted to it.
1801 guests, 161 members online
