Thread started 30 Oct 2010 (Saturday) 22:01
Very small, very light monopod
jr_senator
Oct 30, 2010 22:01 |  #1
Very small, very light monopod that's what I'm looking for. The Gitzo GM2561T seems the only decent choice but kind of expensive. Any other ideas?
midget
Oct 31, 2010 01:07 |  #2
how tall do you need this monopod to be? i have to say that i'm quite pleased with my induro cm25, but it's a bit short for anyone over 5'8.
40d + 50mm f1.8 MK I + my feet.
PG1
Oct 31, 2010 02:50 |  #3
jr_senator wrote in post #11195961 (external link)
Consider this Induro carbon Monopod - CM24 - I am very happy with it - it is light, strong and the locks are very nice.
http://www.amazon.com …TF8&qid=1288511​280&sr=8-3 (external link)
Too much gear, not enough skill or time!
Canon R, Sony a7III, EF 24-70 II L, EF 70-200 II f/4.0 L, RF 100-500 L, RF 35 1.8, RF 800mm f/11, Sigma 85 1.4 DG DN, Voigtlander 35 1.2 SE. Gitzo 2545T, 3541LS, Markins Q3T, Q20.
lannes
Oct 31, 2010 03:12 |  #4
The Induro CM25 is a bit smaller
http://www.bhphotovide​o.com …_Carbon_8X_CM_S​eries.html (external link)
johnf3f
Oct 31, 2010 18:39 |  #5
I use the Gitzo GM2541 - it's a little longer when retracted but more rigid and supports a 1d xx body + 600 f4is without complaint.
They are very expensive but they are worth it! I would suggest the 4 leg section version as it's more rigid than the 6 and quicker to set up - I just wish they made 2 section monopods!
Life is for living, cameras are to capture it (one day I will learn how!).
Grampajohn
Oct 31, 2010 20:34 |  #6
If you like hiking with your camera, take a look at the Leki Sierra Photo walking pole. It looks like a regular Leki pole with a grip and strap but it has a spiffy wooden knob at the end that unscrews from the top of the pole and reveals a tripod screw on which you can thread your camera.
jr_senator
Nov 01, 2010 19:37 |  #7
I will be using the monopod with a G series sized camera. The Induro CM25 looks interesting. I still like the 3" shorter folded length and slightly less weight of the Gitzo GM2541 but $160 less for the CM25 is attractive and it certainly is small and light. Gotta think about this.
Jon
Joined Jun 2004
Nov 01, 2010 20:14 |  #8
For a G series? Get a trekking pole.
REI Four Winds Travel Trekking Pole - 23" and around 4 oz. collapsed. (my luggage scale shows it at 4 oz., but that's not going to be very precise at that level. Well under 1/2 lb. anyhow.
IMAGE: http://jonbarrettphoto.smugmug.com/photos/1073786665_TNoMz-L.jpg
IMAGE: http://jonbarrettphoto.smugmug.com/photos/1073786332_qP2hQ-L.jpg
Extends to 49".
Jon
Cocker Spaniels
2mnycars
Nov 01, 2010 20:45 |  #9
Thanks Jon; hadn't seen that one.
Dave
jdizzle
Darth Noink
Nov 02, 2010 03:55 |  #10
Jon wrote in post #11207589 (external link)
Extends to 49".
After removing the rubber handle, will the metal piece sticking out at the top of the pole screw onto the camera?
Jon
Joined Jun 2004
Nov 02, 2010 09:06 |  #11
Yep. Standard 1/4-20 thread. Most single trekking poles have that feature (not many of the "pairs" do though). This one's charm is that it's small enough to pack in the average suitcase.
Jon
Cocker Spaniels
jdizzle
Darth Noink
Nov 02, 2010 10:30 |  #12
Jon wrote in post #11210161 (external link)
Cool! I didn't know that! Thanks! :)
midget
Nov 02, 2010 17:36 |  #13
after hearing that it's for a G-series even the cm25 could be overkill. a trekking pole should be enough for it though the cm25 would definitely be more flexible in case you wanted to use it for other purposes in the future.
rang
Nov 02, 2010 19:04 |  #14
jr_senator wrote in post #11207346 (external link)
Here is what I used with my G9 plus Canon flash (270EX and Canon wide angle and telephoto lenses on Lensmate adapters) Worked in the Grand Canyon, Zion, Bryce and Yosemite hiking. Water and dry hikes.
http://www.amazon.com …TF8&qid=1288742​516&sr=8-1 (external link)
Lotsa stuff, running outta room and a wife...I keep looking at her and wondering??? :lol:
Jon
Joined Jun 2004
Nov 02, 2010 19:33 |  #15
Extends to 49".
Since the piano and light falloff from the SD990 flash make viewing of the dark bits a little difficult . . .
IMAGE: http://jonbarrettphoto.smugmug.com/photos/1075257674_xBVFr-L.jpg
Jon
Cocker Spaniels
7,909 views & 0 likes for this thread, 11 members have posted to it.
555 guests, 121 members online
