Thread started 31 Oct 2010 (Sunday) 17:22
S95 RAW CONVERSION HELP
brolic
Oct 31, 2010 17:22 |  #1
Am I unable to use DPP to convert my RAW files to .JPEG's?
If so, how am I able to convert files?
Needsnow
Oct 31, 2010 17:26 |  #2
You probably need to have the latest version of DPP that came with the S95 loaded. It is 3.9.0.2 and I can work with the RAW files without any issues.
Canon EOS R
brolic
Oct 31, 2010 18:27 |  #3
Needsnow wrote in post #11200035 (external link)
Have the software that came with 7D installed. Am I unable to use this version?
Needsnow
Oct 31, 2010 18:28 |  #4
Don't need to uninstall it, I think. I didn't.
Canon EOS R
Jon
Joined Jun 2004
Oct 31, 2010 20:02 |  #5
The S95's newer than the 7D; ZB that ships is 6.6 vs. 6.5, and RAW is much more version-dependent than JPEG, so I'd suspect you do. The latest Canon has listed for the 7D is DPP 3.81. Just install the S95's software over the 7D's and you should be OK. The programs are all backwards-compatible.
Jon
Cocker Spaniels
adwoodw
Nov 01, 2010 00:05 as a reply to  @ Jon's post |  #6
I had the same problem initially as well since I also have a 7D. Just do an install with the S95's discs and you are good to go. :)
Canon 7D | Canon T1i |Canon 50mm f1.8| Canon 18-55mm f3.5-5.6 |Canon EF-S 15-85mm IS | Sigma 18-200 f3.5-6.3 DC OS | Sigma 18-50 f2.8 EX DC Macro|Crumpler 5MDH | Kata 3 in 1 20 |Crumpler 6 MDH | Canon S95 | Lowepro D-Pods 20
brolic
Nov 01, 2010 01:32 as a reply to  @ adwoodw's post |  #7
Thanks all for the help. Should have figured it would have been something as simple as that.
Will download that version as well and if that doesn't work I'll be posting back here.
2,789 views & 0 likes for this thread, 4 members have posted to it.
Latest registered member is Cutiepiewee
919 guests, 123 members online
