dmward wrote in post #11211986
Somewhere on the forum I saw reference to this and can't find it.
I am looking for an Edison socket adapter that will permit me to plug in the small 120 v halogen lamps.
This will solve the problem with modeling lights protruding too far from the socket for the PLM V2 mount to work with the modeling light in place on Genesis (and Maybe Elinchrom) monos.
There's another way to do this without using the pricey Edison-to-bi-pin adapter. Some time ago, I bought a used Elinchrom 600RX from a seller in Canada. Who knew Canadian Elinchroms use Edison base rather than bi-pin base modeling light bulbs? I didn't. Anyway, the light looked like this when it arrived:
My US-purchased Elinchroms have small bi-pin halogen modeling light bulbs. I swapped out the stock bulb for a small bi-pin with integral Edison base:
As you can see, the replacement Bulbrite bulb is significantly shorter than the stock bulb. In either case, using a PLM V2 cage is a non-issue:
The short halogen costs $5.22:
http://lightbulbemporium.com …ite_612150_q150cl_e26.asp
Dave F.
