After you have used a Rocket Blower to remove dust, is it okay to use Pec Pads and Eclipse to clean the lens? Or is it strictly for the sensor? Thanks.
993cpe Mostly Lurking 15 posts Joined Aug 2005 More info | Aug 30, 2005 18:26 | #1 After you have used a Rocket Blower to remove dust, is it okay to use Pec Pads and Eclipse to clean the lens? Or is it strictly for the sensor? Thanks.
LightRules Return of the Jedi 9,911 posts Likes: 5 Joined Jun 2005 More info | Aug 30, 2005 18:33 | #2 For the lens front element, simply use a microfiber/lens tissue with a drop(s) of lens solution, then wipe in a circular motion. In all honesty though, you don't need to clean/wipe your front element all that much. Air blowers are by and far sufficient.
Mitcon Goldmember 3,670 posts Likes: 3 Joined Jun 2005 Location: Adelaide, South Australia More info | I'll second that, it's rare I ever need more than to just use the squeeze bulb. Cheers Wayne
tim Light Bringer 51,010 posts Likes: 375 Joined Nov 2004 Location: Wellington, New Zealand More info | Aug 30, 2005 21:09 | #4 Don't use sensor cleaner to clean a lens, use lens cleaner. Get a kit from a local store or from copperhill, they do good lens cleaning kits as well as sensor cleaning kits. Professional wedding photographer, solution architect and general technical guy with multiple Amazon Web Services certifications.
| Latest registered member is Thunderstream 1889 guests, 105 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
