I need some.
I know I definitely need more than one for the range of shooting I'm going to be doing. I'm going to need at least one to cut down on power for portraiture and one for automotive photography.
What's the best solution with keeping money in mind?
There's a Tiffen kit on B&H that has a 1, 2, and 3 stop filter for $120. That's fairly cheap, but I don't think that those filters are going to cover the range I need.
I know I don't want a cheap filter, so looking at B+W 77mm ND filters, they're about $80 each, so two filters would cost me about $160, three would be about $250. Is there a cheaper brand that is a good quality that won't give me negative results when using it?
The last option is a bit expensive. Singh-ray makes an adjustable ND filter that's $340. I may be able to find it cheaper, but it adjust from 2-8 stops with just one filter. Would I be better off in the long run with something like this?
