Thread started 04 Nov 2010 (Thursday) 11:21
100% crop useful for cameras of different pixel density?
RTPVid
Nov 04, 2010 11:21 |  #1
I know this has probably been discussed... maybe even to death, but a forum search results in a deluge of threads with have nothing to do with the narrow topic of how useful (or not... I claim not) is using 100% crop to compare (for example) high ISO noise between cameras of different pixel densities but similar sensor size (e.g. APS-C).
It seems to me the useful comparison is the same image "physical" size rather than 100% crop, which automatically puts the higher pixel density sensor at a disadvantage (because it is "blown up" more) and is a mostly useless comparison in the real world of photographers. It has use to sensor designers, but not photographers.
Can anyone provide a link to a "definitive" thread on this topic?
If not, maybe we can start a discussion (again?) on it.
Tom
RTPVid
Nov 04, 2010 11:25 |  #2
Sorry... posted in wrong forum... Can the mods please move it to the EOS camera forum? Thanks.
Tom
RaZe42
Nov 04, 2010 12:37 |  #3
Maybe the best solution to this problem is simply not to measurebate too much. :)
Gear: Canon 5D Mk II | Olympus 21/3.5 | Zeiss Distagon 35/2 | Sigma 50/1.4 ASPH | Samyang 85/1.4 ASPH | Canon 100/2.8 L Macro
My modest Flickr (external link)
bohdank
Nov 04, 2010 13:11 |  #4
The only meaningful comparison is to look at them at the same physical size, 8 x 10, for example.
kcbrown
Nov 04, 2010 13:38 |  #5
RTPVid wrote in post #11223978 (external link)
It depends on how different the pixel densities are.
Comparing a 16 megapixel APS-C sensor to an 18 megapixel APS-C sensor at the pixel level is useful because they're both roughly the same pixel density -- enough that resizing one to match the other isn't going to make much of a difference. But comparing a 10 megapixel APS-C sensor to an 18 megapixel APS-C sensor (or even a 15 megapixel APS-C sensor) can't really be done properly on the pixel level since the pixel densities are sufficiently different that resizing to match (when done properly of course) will have a marked effect on the result.
"There are some things that money can't buy, but they aren't Ls and aren't worth having" -- Shooter-boy
Canon: 2 x 7D, Sigma 17-50 f/2.8 OS, 55-250 IS, Sigma 8-16, 24-105L, Sigma 50/1.4, other assorted primes, and a 430EX.
Nikon: D750, D600, 24-85 VR, 50 f/1.8G, 85 f/1.8G, Tamron 24-70 VC, Tamron 70-300 VC.
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Nov 04, 2010 13:40 |  #6
I don't think 100% crops are good for looking at camera sensors at all.
I use it to help see how my focus, the bodies AF, and sometimes how lenses are behaving .. but only on the rarest of occasions.
For ISO noise, the trouble is that detail = more noise,. less noise = less detail. So for a 100% crop the image with the least detail will look best,. but when viewing the entire image at normal print sizes,. one will often quickly find that the image with the least noise had the least detail and therefore is not the best.
YMMV
CDS' HOT LINKS
alpha_1976
Nov 04, 2010 13:42 |  #7
Unless you have a point what's the point :p
I know more about gear than I know about photography :p
tonylong
...winded
Gallery: 60 photos
Nov 04, 2010 13:42 |  #8
Heh! It's all in what you want to see! For some types of photography and much "normal" use most noise doesn't matter much because it gets lost in small prints and image compression. For other types it matters a lot (things like birding and wildlife are examples because they often require close crops). So, examining the noise characteristics of various cameras can be important to some photogs and relatively meaningless to others. Now, your point about comparing cameras of a different pixel density is a point to consider, for sure, when viewing images at the same time, since the higher res image will be less enlarged and less noise may be visible, but then bear in mind that one of the big reasons why people buy the higher res cameras is because they want more cropping room, which then gets us back to the question of relative noise characteristics.
So, you get a feel for what's meaningful to you and your photography! My criteria may differ! And Joe Shmoe may have his own criteria!
In other words, don't fall into the syndrome of judging what other people are interested in by your own personal criteria...
Here's a thread that has been active over the past couple months with some interesting comparisons between the 7D and the 5D2:
https://photography-on-the.net/forum/showthre​ad.php?t=930196
Tony
Jim_T
Joined Nov 2003
Nov 04, 2010 19:10 |  #9
I can see pixel density entering into the equation..
Consider shooting a full moon with a 400mm lens... First on a 5DII and then on a 7D.
The 5DII moon will be about 700 pixels wide and the 7D moon will be about 1000 Pixels wide. So should the 7D image be down sampled to the same 700 pixels as the 5DII image to truly compare the images?
Would downsampling reduce the effects of noise slightly?
tonylong
...winded
Gallery: 60 photos
Nov 04, 2010 19:53 |  #10
Jim_T wrote in post #11226375 (external link)
Well, for the moon you typically don't want to shoot at a high ISO:)!
But, sure, to compare directly with the 5D image at the same image size you'd have more pixels in the 7D image and sure you have the 7D image a bit more compressed, but when I'm shooting wildlife I'm not comparing it to a 5D2 image -- I often have to crop at or close to a 100% crop:)!
Tony
JeffreyG
Gallery: 42 photos
Nov 04, 2010 20:30 |  #11
Looking at 100% crops is only of use if you understand and can account for what you are used to looking at.
Once upon a time I did my sharpening and noise reduction at 1:1 views with my 8MP 30D.
When I got a 12MP 5D I would often toggle between a 1:1 view and a 1:2 view. Same with the 10MP 1D Mark III, though I mostly watched 1:1 views with this camera for noise and sharpening.
Now with the 16MP 1D Mark IV I usually do my NR and sharpening at 1:2. I find that NR done at 1:1 generally leads me to excessive NR application and plastic looking skin in even 16x20 prints. 1:2 image viewing on a 16MP image is better for even large prints.
Daniel ­ Browning
Nov 04, 2010 20:42 |  #12
I would argue that this thread I made covers exactly what you're talking about in a definitive manner:
Small pixel sensors do not have worse performance
Specifically, see the section on "Spatial Frequency" -- the number one most common type of flawed image analysis.
Daniel
RDKirk
Adorama says I'm "packed."
Joined May 2004
Nov 04, 2010 20:58 as a reply to  @ Daniel Browning's post |  #13
Wow! Someone who got it, right off the bat. Congratulations!
AJSJones
Gallery: 6 photos
Joined Dec 2001
Nov 04, 2010 21:41 |  #14
JeffreyG wrote in post #11226772 (external link)
+1
If you can understand the relationship between your 100% view and your print at the desired print size, then it is a useful thing to look at.
If not, then you should make the prints you want and see how they come out with different processing methods *while you keep track of your enlargement factor*
If you only make the same print size all the time, then you don't have so much to keep track of.
However, if you vary your cropping extent but keep a fairly standard print size, your degree of enlargement will be all over the place. Therefore, knowing that it looks like X in the 100% view is a reference point that can be useful.
If you bought a higher MP camera/sensor so you could make bigger prints by using all the pixels, then 100% view will be a significant evaluation view.
My picture galleries (external link)
1,853 views & 0 likes for this thread, 12 members have posted to it and it is followed by 2 members.
1380 guests, 135 members online
