Thread started 31 Aug 2005 (Wednesday) 05:23
USB / Raw files / PC connection
Dew
Aug 31, 2005 05:23 |  #1
Just a quick question(s!) - I don't have my manual to hand, and my card reader's at home. When I connect my 350D to my works PC via USB, I can't see my raw cr2 files if I use 'PC connection', although I do see the DCIM folders in explorer (empty). If I use 'Print/PTP' my camera flashes 'busy' all the time, although I can see all my cr2's, but not in the folder structure.
Is the 'busy' normal?
Why no cr2's with 'PC connection'?
Why no folder structure with 'Print/PTP'? (Is this something to do with a simplified structure for printer??)
As you can probably tell - I usually use a card reader :)
Cheers!
EOS 1D MkIV | EOS 40D | BG-E2N | EOS 30D | BG-E2 | EF 50mm f/1.4 USM | EF-S 17-55mm f/2.8 IS USM | EF 16-35mm f/2.8L II USM | EF 70-200mm f/2.8L IS USM | EF 300mm f/4L IS USM | EF 400mm f/4 DO IS USM | Extender EF 1.4x II | Tamrac Model 5575 Expedition 5
flickr sets (external link)
adebass
Aug 31, 2005 08:39 |  #2
What software do you have on your work PC? Can it definatly open RAW files?
Dr Adrian Bass (www.adrian-bass.fotopic.net (external link))
EOS 5D + BG-E4 grip, EOS 10D + BG-E3 grip
Canon EF 24-105L, Tokina 19-35mm,
Sigma 50-500mm
Dew
Aug 31, 2005 08:58 as a reply to  @ adebass's post |  #3
When I set the camera to 'PTP', I can see them (all in one 'directory') and copy them fine, and then open them fine in either M$ Raw Thumbnailer & viewer, or DPP as at home. I was wondering why I can't see them in 'PC Connection' mode.
Dew
Sep 02, 2005 05:22 |  #4
ttt
anyone? :(
with card reader I copy across DCIM folder & subs - job done, with cable I have to manually recreate DCIM sub folders (e.g. 290CANON), select & copy the correct numbered image groups (e.g. _MG9001.cr2 - _MG9100.cr2)
Falkon
Sep 02, 2005 05:47 |  #5
Try this
http://consumer.usa.ca​non.com …odelid=11154#Ne​w%20Window (external link)
There are 10 types of people in the world:
Those who understand binary, and those that don't.
My Wish List (external link)
Dew
Sep 02, 2005 06:14 as a reply to  @ Falkon's post |  #6
cheers big ears :)
well I got the manual, but I can only find the attached page referring to the connections - and it doesn't give much away. It does say that the PC connection won't work if it's set to 'PTP/Print' - but it does, and that's the only way I can see my RAW files.
When set to 'PTP/Print' it appears as 'Canon EOS 350D DIGITAL' under 'My Computer', and under it is a list of the cr2 files. When set to 'PC Connection it appears as 'EOS Kiss_N REBEL_XT 350D' under 'My Computer', and under it are apparently empty folder (e.g. 290CANON, which contain the cr2's when viewed with a card reader).
m3elmo
Sep 02, 2005 13:53 |  #7
i can't copy raw files on my 20d for some reason either..so i just use the card reader and it works there.
Danny
http://photobucket.com​/albums/b103/m3elmo/ (external link)
some random pics...
2,689 views & 0 likes for this thread, 4 members have posted to it.
1508 guests, 129 members online
