Thread started 05 Nov 2010 (Friday) 14:41
Could it be a serious problem with Canon 5D Mk2?
Cherepashka
Nov 05, 2010 14:41 |  #1
Hello everyone.
Today, at the end of the photo shoot all of a sudden my camera has droped the appeture to a -2 and wouldn't let me corect the exposure. The digit on the display screen showed 00, and i've tried everything (took the battery out, memory card out, switched it off and on etc.) Nothing.... so had to finish the shoot with my old camera and in the mean time leave my 5D switched off. After about 40 minutes switched the camera on, still everything was the same. Again off and on and the camera now seems to be working fine.
Could anyone explain what has happened and whether i need to service my camera?
Thank you
Bob_A
Gallery: 48 photos
Joined Jan 2005
Nov 05, 2010 16:03 |  #2
Did you try a different lens?
Bob
Cherepashka
Nov 05, 2010 16:33 |  #3
no, i did not. but if it was a lens problem why then it went back to normal after some time?
Jamesino
Nov 05, 2010 17:11 |  #4
Maybe you accidentally de-attached the lens?
casaaviocar
Nov 05, 2010 18:24 |  #5
Cherepashka wrote in post #11232158 (external link)
stuck aperture blades? flakey contact?
Rule books are paper they will not cushion a sudden meeting of stone and metal -ekg-
philwillmedia
Nov 05, 2010 20:38 |  #6
Probably just dirty contacts on the lens.
Same thing has happened to me several times over the years.
Regards, Phil
2019 South Australian Country Press Assoc Sports Photo of the Year - Runner Up
2018 South Australian Country Press Assoc Sports Photo of the Year
2018 CAMS (now Motorsport Australia) Gold Accredited Photographer
Finallist - 2014 NT Media Awards
"A bad day at the race track is better than a good day in the office"
Cherepashka
Nov 06, 2010 03:33 as a reply to  @ philwillmedia's post |  #7
Ok, let me get this right: dirty or flaky contacts... more possible that it could have been the problem with the lens then? Any suggestions what shall i do next? Service the camera or the lens? I've only bought them (canon 85mm f/1.4L) like a month ago?
Nikolas
Nov 06, 2010 03:36 |  #8
It's definitely a lens contact issue, just be careful, clean the contacts.
Some users have reported accidentally pressing the lens release but I've never done it.
Canon 5D2 20D & 300D 50mm f1.8 mk 2, 24-105 f4 IS L
Tokina 12-24 f4
ATX PRO, 400mm f5.6 ATX apo
Sigma 28-70mm f2.8
EX DG, 120-300mm f2.8 EX DG
Tamron SP pro TC 1.4 and KENKO 2x teleplus pro 300DG and lots of m42 lenses
Cherepashka
Nov 06, 2010 13:18 |  #9
Hey, one more quastion about the lens then: aren't 85mm 1.2L lenses helping to find the focus automatically after you press the shutter button half way? I think my lenses use to do this, but they doesn't anymore? And how come the lenses can be dirty all ready if i've only used them for 1 month or so?
casaaviocar
Nov 06, 2010 13:36 |  #10
I won't guarantee it's the lens or the contacts, but that is as likely a culprit as the body is.
If you've fingered the contacts, they certainly could be dirty after only a month, fingering them could also lead to something stuck or bent. Canon specifically says to avoid touching the contacts, not saying you have, but this could certainly lead lens communication problems.
As far as AF goes, yes at the half press the lens should attempt to focus. Have you switched focus to AI servo? This will be a continuous focus and there will be no confirmation beep, just a gentle hunting all of the time you are half pressed.
When you focus the lens is wide open (at max aperture) the lens has the most light for the AF sensors in this condition, and this helps with the AF. If the blades are stuck this may mess with the AF because it's too dark, if you are in AI Servo you'll never get confirmation because the focus is looking for moving subjects.
Cherepashka
Nov 07, 2010 07:22 |  #11
hey guys, thank you a lot for all your replays. You are live savers! :)
2,362 views & 0 likes for this thread, 6 members have posted to it.
1441 guests, 135 members online
