Thread started 05 Nov 2010 (Friday) 15:36
Tamron Lens Phenomenon
stax
Nov 05, 2010 15:36 |  #1
I just saw this post over at Canon Rumors and thought some here would be interested:
Tamron Lens Phenomenon  (external link)
from Canon Rumors » Blog Archive » New Video Camera? (external link) by Canon Rumors
Interesting issue with Tamron Lenses
I received this information a while back, I didn’t post it until there was some kind of response from Tamron.
The following is a direct quote from the folks that found the problem. Tamron’s response is at the bottom.
i am a member of the german dslr-forum (www.dslr-forum.de (external link)), which is probably the biggest german speaking community regarding all DSLR-topics (not only Canon). We observed a phenomenon where the followings lenses won’t use the outer cross-type sensors of EOS 40/50/60/7D cameras right.
The lenses that show this problem are (all Tamron):
  • 17-50 f/2.8 VC
  • 60 f/2 Macro
  • 70-200 f/2.8
  • 10-24 f/3.5-4.5
To get a bit more into the detail of the problem – on the 40/50/60D cameras the outer cross-type sensors only work as line-type sensors. To be a bit more correct, they actually work in the same direction as they would work on cams like the 30D or like the 400/450/500/550D. When it comes to the 7D the outer sensors are also only working as line-type sensors (but it seems, that the EF 50 1.2L also has problems to use them correct).
The center cross-type sensor does work at least as a single-cross type sensor (infact we don’t now how to test if the center sensor is working as a dual-cross-type sensor like it’s supposed to work with those f/2.8 and better lenses).
Tamron seems to not know about this behaviour so far. Well – at least, they didn’t confirmed the problem and only said, that they will investigate this.
Maybe a small addition – the Tamron 17-50 VC uses the same lens-ID as the EF 35-80 – maybe you’ll have the chance to check whether this Canon-lens performs correctly or not.
The link to the thread is: http://www.dslr-forum.de/showthread.ph​p?t=732360 (external link)
Tamron Europe’s Official Response
Dear Mr. S.,
we were able to reproduce the situation where the Tamron 17-50 VC (B005) and the Tamron 60 Macro (G005) won’t use the Canon EOS 50D cross-type sensors correctly.
We have given this information to Tamron in Japan and we are expect an answer very soon.
Best regards
Tamron Europe GmbH
http://www.canonrumors​.com …utm_content=Goo​gle+Reader (external link)
http://www.flickr.com/​photos/staxnet/ (external link)
https://photography-on-the.net/forum/showthre​ad.php?t=865770
richardfox
Nov 05, 2010 16:45 |  #2
Aaaaand, this is why I stick with Canon lenses.
Canon 50D gripped, EF 50/1.8, EF-S 10-22, 17-40L, 24-105L, 70-200 f/2.8L, 100/2.8 macro, 100-400L, 300 2.8L, Canon 500 f8 mirror with chipped EF mount, 580EX, 1.4x and 2x Canon teleconverters, Canon EF Life-Size converter.
District_History_Fan
Nov 05, 2010 16:45 |  #3
Color me surprised... ;)
www.ericmcferrin.smugm​ug.com (external link)
themadman
Nov 05, 2010 16:48 |  #4
I don't own any Tamron lenses but I am kinda surprised regardless.
Will | WilliamLiuPhotography.​com (external link) | Gear List and Feedback | CPS Member | Have you Pre-Ordered Your 3Dx Yet? | HorusBennu Discussion | In honor of Uncle Steve, thanks for everything! 10-5-2011
stax
Nov 05, 2010 16:53 |  #5
themadman wrote in post #11232227 (external link)
Same here. I am mostly surprised that it took this long to identify the problem.
Replaces
Nov 05, 2010 16:53 |  #6
oh wow
this is.... surprising -__-
CountryBoy
"Tired of Goldmember label"
Nov 05, 2010 16:58 |  #7
richardfox wrote in post #11232206 (external link)
I guess you missed the part where it said the Canon 50mm L has the same problems
Hi
bohdank
Nov 05, 2010 18:04 |  #8
I am very curious to hear an explanation of why/how this happens. The lens/body do not communicate which sensor is being used. Why would the lens care and it suggests that Canon bodies in such a way that a cross sensor can switch off one of it's lines. Again, very curious.
gjl711
"spouting off stupid things"
Nov 05, 2010 18:15 |  #9
I'm just wondering how a lens can affect the performance of the AF chip. Isn't an image circle an image circle no matter what glass is put in front of it?
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
CountryBoy
Nov 05, 2010 22:12 |  #10
bohdank wrote in post #11232568 (external link)
Very interesting :confused: . I'm very curious also .
Hi
sangjiny
Nov 05, 2010 22:21 |  #11
CountryBoy wrote in post #11233721 (external link)
+1 very curious.
Leica M9
Pentax 645D
Rolleiflex 2.8FX
Mamiya 7
Zeiss ZI Ikon
Jam.radonc
Nov 06, 2010 05:30 |  #12
Whoa! That interaction between the 50L and the 7D is very interesting. That very much kinda put a stop on me buying the 7D this weekend but how is that even possible?
Jam
5D3 | 450D | Panasonic DMC-LX3 | 430 EX II | ST-E2
24-70 L II | 50L | 50 1.8 I | 100L | Zeiss 35/2 ZE | Zeiss 85/2.8 | Zeiss 135/3.5
[COLOR="Silver"]Sold: 17-40L | 24L II | 85L II | 135L | Sigma 50/1.4 | 5D2
yogestee
Nov 06, 2010 10:02 as a reply to  @ Jam.radonc's post |  #13
"Canon Rumors" :rolleyes:
Jurgen
Logicus
Joined Nov 2010
Nov 06, 2010 10:42 |  #14
My tamron 70-200mm works perfectly with both my 40d and 450d? As does my tamron 10-24mm and so did my friends Tamron SP AF17-50mm F/2.8 XR Di II...
My Gear List
My flickr (external link)
My flickr photos organized by Lens Used (external link)
KenjiS
"Holy crap its long!"
Gallery: 610 photos
Nov 06, 2010 10:49 |  #15
Jam.radonc wrote in post #11234765 (external link)
Indeed, that is intrigueing, especially for a lens like the 50L where precise focus is HIGHLY important
Deviantart (external link)
18,209 views & 0 likes for this thread, 30 members have posted to it.
Latest registered member is Cutiepiewee
573 guests, 146 members online
