Thread started 31 Aug 2005 (Wednesday) 09:13
Selecting smaller image sizes
bokeh'ed
Joined Jun 2005
Aug 31, 2005 09:13 |  #1
when selecting smaller image size other than the maximum resolution, does the camera perform an additional step of downconverting from the max resolution to the required resolution? or simply the image sensor uses a smaller image area to capture shots (much like the D2X)?
Andy_T
Joined Jan 2003
Aug 31, 2005 09:34 |  #2
It converts the image to the smaller resolution, keeping the full frame.
Best regards,
Andy
some cameras, some lenses,
and still a lot of things to learn...
(so post processing examples on my images are welcome :D)
If you like the forum, vote for it where it really counts!
CLICK here for the EOS FAQ
CLICK here for the Post Processing FAQ
CLICK here to understand a bit more about BOKEH
bokeh'ed
Joined Jun 2005
Aug 31, 2005 09:40 as a reply to  @ Andy_T's post |  #3
if that's the case, burst shots using lowered resolution will be slower than that of "full" frame, since additional steps are required by the image processor to downconvert and save to the media?
smasraum
Aug 31, 2005 09:43 |  #4
That would be something, stepping down to a smaller size causes the sensor to further crop the image making your 300mm lens appear like a 1500mm lens. How cool would that be? :D jk
Steve
Canon EOS 60D, 350D, 630
Canon 15-85 IS, 100-400L IS, 50mm 1.8, Canon 18-55mm, Sigma 70-300 APO DG Macro
Canon AE-1 Program w/ Canon 50mm 1.4 and 70-210
Jon
Joined Jun 2004
Aug 31, 2005 10:21 as a reply to  @ smasraum's post |  #5
That's what Noink does (D2X) to get from 5-8 FPS (and that's starting with a 1.5x crop at "full frame"). Be careful what you ask for . . .
Jon
Cocker Spaniels
Andy_T
Joined Jan 2003
Aug 31, 2005 10:23 as a reply to  @ bokeh'ed's post |  #6
bokehed wrote:
=bokeh'ed]if that's the case, burst shots using lowered resolution will be slower than that of "full" frame, since additional steps are required by the image processor to downconvert and save to the media?
Burst shots will be the same speed, but you can actually get more images in the burst with lower resolution, as the critical part is buffer size and the speed of writing the images to the CF card.
Best regards,
Andy
Hellashot
Joined Sep 2004
Aug 31, 2005 11:08 as a reply to  @ smasraum's post |  #7
No. You'd end up with a very tiny recorded image. You wouldn't end up with an image that look like it was taken with a huge zoom.
5D, Drebel, EOS-3, K1000
lenses from 12mm-500mm
Jim_T
Joined Nov 2003
Aug 31, 2005 11:19 as a reply to  @ Andy_T's post |  #8
The conversion of the varying voltages produced by the CMOS sensor to a computer file format like JPEG is a fairly major task. There are a lot of steps involved and the EOS digicams have pretty powerful internal computers to accomplish this.
I doubt the extra step of downsampling the image during this proces would make any difference at all in the time it took to create the JPEG.
1,695 views & 0 likes for this thread, 6 members have posted to it.
1167 guests, 183 members online
