Last few days visited a wild life sanctuary and photographed extensively using my Sigma18-200 (mostly used at 200mm focal range). Photograhs after some sharpenning & cropping with Canon supplied software, have come out accepatable / good.
I am thinking of upgrading to some better quality optics with following specs
1. Should also be good for portraits (only as stand by to Canon 50F1.4)
2. Preferably can take close up shots of rose/ flower sized items (say ~1:3 macro)
3. Basic use will be hand held photography outdoors (During my recent trip, clicked mostly at 200 mm and then cropped a number of them. Therefore I assume that some additional focal length, say upto 250 or 300mm would be good)
4. Around 600-700 USD
Canon 70-300 IS version is rated well in some reports. Tamron also has come out with VC version of this focal range. Kindly help me to figure out following
1. Is Tamron comparable to Canon in 150-300 focal range. Kindly post photographs using two lenses.
2. Is canon 70-300 better than canon 55-250 (I assume so)
3. Canon 70-200 F4 (non IS) is similarly priced. If I can get 7 /10 good shots, hand holding and at 200mm, I wont miss IS.
4. I am inclined towards primes. If I buy one of the primes, say 100 or 135 or 150 and then use it in outdoor situations (say wild life sanctuary) and crop the pictures to get 200 mm equivalent object. Will the result be better than picture taken with one of above zoom lens, set at 200mm
Which lens will you recommend (Being a hobyist, intend sticking to APS-C format).
Thanks in advance.
