Thread started 08 Nov 2010 (Monday) 07:51
NeckStrap name?!
Shamir
Nov 08, 2010 07:51 |  #1
How is it call, or who sells the neck strap that goes around your neck and just plugs in on the camera tripod mount?!
Bert Stephani uses it on his MOTIVATIONAL LIGHT DVD which I just got!
Shamir
My Website - Click Here (external link)
MSIGuy
Nov 08, 2010 08:03 |  #2
Black Rapid R-Strap
Some cameras, some lenses, plenty of gaffer's tape and beer.
Shamir
Nov 08, 2010 09:58 |  #3
Thanks bro!
Shamir
alameda
Nov 08, 2010 17:52 |  #4
Shamir wrote in post #11245590 (external link)
Try Luma Loop - http://www.luma-labs.com/products/loop (external link)
Op/Tech - http://optechusa.com/u​tility-strap.html (external link)
I have both - and they both are great - zero problems. The best bang for the buck is the Op/Tech rig. You bup the regular neck strap and then the utility strap. Cheaper than either the Luma Loop or BR.
I looked at the BR and decided that the reports of falilure were too often and I didn't like the metal connectors.
Alameda
TritonB7
Nov 08, 2010 20:38 |  #5
alameda wrote in post #11249020 (external link)
Alameda
The connector that mounts to the bottom of the camera or the clip that connects to it?
My Gear | My Rig | My Flickr (external link)
AdamC
Nov 08, 2010 21:06 |  #6
Judging from Optech's site, it appears that theirs attaches to the normal neckstrap loop rather than the tripod hole. I don't know about anyone else, but that would be a fail for me - I HATE having stuff hanging down like that. The BR appealed to me (still haven't bought one yet) because attaching to the tripod thread gets it nicely out of the way.
[gallery (external link)|gear|flickr (external link)|blog (external link)]
Rum ­ Maximus
Nov 08, 2010 21:22 |  #7
AdamC wrote in post #11250076 (external link)
Seems like you could still buy one of the BlackRapid mounting points and connect the OpTech strap to it.
Micro4/3: : E-PL5 + VF-3 | Lumix 14mm ƒ/2.5 | Oly 14-42mm ƒ/3.5-5.6 IIR | Lumix 45-150mm ƒ/4-5.6 | Oly FL-600R
M39/M42 : Super-Takumar 28mm ƒ/3.5 | Mir-1 37mm ƒ/2.8 | Super-Takumar 50mm ƒ/1.4 | Industar-50 50mm ƒ/3.5 | Petri CC Auto 55mm ƒ/1.8 | Jupiter-9 85mm ƒ/2 | Carenar 135mm ƒ/2.8 | Jupiter-37A 135mm ƒ/3.5 | SMC Takumar 200mm ƒ/4
AdamC
Nov 08, 2010 21:34 |  #8
matthew1371 wrote in post #11250159 (external link)
Yeah, or use the D-ring on your RC2 plate or whatever, for that matter.
eeeksNYC
Nov 08, 2010 22:39 |  #9
I think the one that Burt uses is actually the Sunsniper
http://www.sun-sniper.de/index.php?id​=2&L=1 (external link)
eeeksNYC (my blog (external link), my flickr (external link))
zeiss ikon icarex 35s,5D MK1/ EF 28-70 f2.8L / Sigma 50mm f1.4 / Sunpak 383s / Cybersyncs / and a couple bags of other stuff....http://www.flickr.com/​photos/29075737@N02/ (external link)
mudanoman
Nov 08, 2010 22:48 |  #10
Another alternative is the Custom SLR C-Loop which uses your existing camera strap and attaches to the tripod mount of your camera. A good alternative if you already have a strap you like using.
Its on Kickstarter currently: http://kck.st/crzgWT (external link)
Custom SLR (external link)
Free Your Camera™
mike_d
Nov 08, 2010 23:06 |  #11
I have OpTech's sling and have the lanyard attached to the strap lug of my L plate. Works great and never gets in my way.
viktorsundberg
Nov 09, 2010 02:52 |  #12
Hmm, that black rapid looks nice, but I always have my tripod plates screwed to the camera and lens mounts :/
5D mk III | TS-E 17 f/4L | 50 f/1.4 | 70-200 f/2.8L IS II | 100 f/2.8L Macro IS | 300 f/2.8L IS | 600 f/4L IS II | 1.4x III | 2x III | Gitzo tripods | RRS ballheads | Wimberley gimbal
Photographer and author from Sweden. Teacher at Canon and organizer of independent workshops. Visit my website: www.viktorsundberg.se (external link)
SMP_Homer
Gallery: 29 photos
Nov 09, 2010 07:58 |  #13
AdamC wrote in post #11250227 (external link)
Highly not recommended
It will hold light gear, and probably will for a long time
once you start putting anything heavy, and that swings around a little, the stress will split the ring out of the screw...
stick the business end of a pair of needle nose pliers in that ring, and then spread the pliers out - you'll see it stretches rather easily...
EOS R6’ / 1D X / 1D IV (and the wife has a T4i)
Sig35A, Sig50A, Sig85A, Sig14-24A, Sig24-105A, Sig70-200S, Sig150-600C
100-400L, 100L, 100/2, 300 2.8L, 1.4x II / 2x II
600EX-II X3, 430EX-III X3
alameda
Nov 09, 2010 13:51 |  #14
Alameda
You can purchase a loop connector that screws into the camera or tripod mount from Luma Loop - the strap comes with one or you can purchase one from any of the others like BR or the Sun Sniper?? (forgot the name).
I use the Luma Loop connector with the Op/Tech strap and Luma Loop strap. Most often I use a split ring on my camera lug. I have had zero problems and the loops on both the Op/Tech and Luma Loop don't exert as much pressure as the BR attachments the apparently loosen the connectors that too many people complain about. There is also not a metal problem to content with - scratching and so forth.
The Op/Tech strap uses the neck pad from the normal Op/Tech neck strap with the Utility Strap. The setup hangs just like the BR or the Luma Loop - go to the web site and check it out. For the price of a Luma Loop, BR or other maker you end up with a great neck strap and a shoulder strap for less money. Alameda
2,550 views & 0 likes for this thread
NeckStrap name?!
Latest registered member is m.nobles
850 guests, 217 members online
