Thread started 09 Nov 2010 (Tuesday) 17:26
Mid-price polarizers
jt354
Nov 09, 2010 17:26 |  #1
I'm looking for a decent CPL in the $80-130 price range and it seems there are relatively few options. The B+W uncoated filter is ~$100, is it a major step down in quality from the Kaesemann filters? I've also seen some threads about Marumi polarizers, how do they compare?
Zenfolio (external link)
Gear: Canon 60D / Canon G12 / Tamron 17-50 f/2.8 / Canon 35mm f/2 IS / Canon 85mm f/1.8 / Tamron SP 70-300mm f/4-5.6 / Speedlite 430 EXII / Slik 700DX legs / Cullmann MB6 head
Jon
Joined Jun 2004
Nov 09, 2010 17:52 |  #2
Kaesemann isn't the only option for multicoated CPLs. B+W makes non-Kaesemann MRC circular polarizers. The B+W MRC 58 mm CPL is $93.50 at B&H; the 67 mm is $117. If you're looking for a CPL for your 10-20, however, bear in mind that it'll give you a very uneven effect across a clear sky since that lens covers such a wide AoV that you'll be able to see the difference between a CPL at right angles to the sun and one aimed along the line of the sun. For that you'd be better off with a graduated ND filter (square, not round) to hold back the sky.
Jon
Cocker Spaniels
Needsnow
Nov 09, 2010 17:53 |  #3
I have and use the Marumi 77mm polarizer. I used to have the B+W. I like the Marumi just as well.
Canon EOS R
crn3371
Nov 09, 2010 19:28 |  #4
I have an uncoated B+W cpl that I use on my 100-400 with no ill effects. Another option would be one of the multi-coated Hoya's if you want to save money over the B+W. Keep in mind what Jon said about using one on your 10-20.
jt354
Nov 09, 2010 20:32 |  #5
Thanks! I was thinking I'd get a 77mm and use a step-up ring with the 70-200mm f/4L, but I may go for a 67mm instead. My lens collection is constantly changing though, do these things hold their value? (Otherwise I'd probably just get the 77mm) I have a hitech ND grad that I'm using with the Sigma for the reason mentioned.
HyperYagami
Nov 09, 2010 20:43 as a reply to  @ jt354's post |  #6
Try Kenko Pro1. They're the exact same as Hoya Pro1 (same company) and usually costs less.
5D3 and a few lens
es.
halitime
Nov 09, 2010 20:47 |  #7
Kenko Pro 1D work well but a step up ring doesn't let you use the hood at all.
Gear List : 1D MK II n,Gripped XSi,70-200 f4,300 f4 IS,Canon 24-105 f4,35 f2 IS,EF 50 1.8 MK I,EF-S 10-22,Canon 1.4 II Extender,Canon 25mm Ext Tube,YN 468/460 II,RF 602's
http://www.flickr.com/​photos/halitime/sets/ (external link)
jt354
Nov 09, 2010 21:03 |  #8
^Wouldn't using a hood (on a telephoto) be maddening with a polarizer anyway? I feel like I'd constantly be smudging it by accident.
crn3371
Nov 09, 2010 21:14 |  #9
I use CPL's on both my telephotos. It's kind of a pain, but I've become fairly adept at sticking my finger in there to turn it. I wish Canon would do like some of the other mfgs. and either put a little access port on the hood, or a thumb wheel.
Mike ­ K
Joined Apr 2001
Nov 09, 2010 21:39 |  #10
The Marumi DHG CP for $69 or Super DHG CP for $114 for the 77mm size, and less for smaller sizes.
http://www.2filter.com …/marumicirpolar​izers.html (external link)
How do they compare? The Marumis did quite well in this set of measurement tests:
http://www.lenstip.com …arizing_filters​_test.html (external link)
http://www.lenstip.com …Hoya_HD_CIR-PL_72_mm.html (external link)
The Marumi Super DHG tied for fist place.
Canon 6D, 1DmkII, IR modified 5DII with lots of Canon L, TSE and Zeiss ZE lenses
plasticmotif
Nov 10, 2010 08:52 |  #11
this should be stickied.
Mac P.
My Zenfolio (external link) My Photo Blog (external link) My Equipment
https://photography-on-the.net …p?p=14172975#po​st14172975
ben_r_
-POTN's Three legged Support-
Nov 10, 2010 12:18 |  #12
plasticmotif wrote in post #11258415 (external link)
Very good link!
worrptangl
Nov 10, 2010 13:11 |  #13
Wow that's a lot of filter's they tested.
mikemo618
Nov 10, 2010 13:27 |  #14
Agreed. I spent a lot of time looking at that when I bought my Marumi. I have the Super DHG (grabbed it off ebay for like $95) and it has been fantastic thusfar.
5D2, 7D, 70-200 2.8L, 24-70 2.8L, 16-35L ii, 135L , 50 1.4, and other assorted goodies.
500px (external link)
ben_r_
Nov 10, 2010 14:10 |  #15
IMO, save youre money until you can afford a high end one. You wont regret it and you can rest assured you own the best tool for the job.
2,477 views & 0 likes for this thread
Latest registered member is dsk26894
1192 guests, 333 members online
