Recently cracked the glass covering the LCD screen. Canon Canada wants a flat rate of $300 to replace the glass. Looking for less expensive alternatives.
Anyone ever replaced this themselves?
Any aftermarket solutions?
TIA
FeXL Senior Member 493 posts Likes: 3 Joined Dec 2007 More info | Nov 12, 2010 15:08 | #1 Recently cracked the glass covering the LCD screen. Canon Canada wants a flat rate of $300 to replace the glass. Looking for less expensive alternatives.
GPFocussed Senior Member 584 posts Joined Jan 2009 Location: Canada More info | Nov 12, 2010 16:28 | #2 Not for a 1D but have you had a look at this link? [URL="http://photography-on-the.net/forum/Gear List"][URL="http://photography-on-the.net/forum/showpost.php?p=9541640&postcount=2194"]Gear List
joeseph "smells like turd" More info | Nov 12, 2010 17:35 | #3 They're only stuck on with doublesided tape gaskets... some fairly old canon camera stuff, canon lenses, Manfrotto "thingy", and an M5, also an M6 that has had a 720nm filter bolted onto the sensor:
eb314 Senior Member 314 posts Joined Nov 2008 More info | Nov 12, 2010 17:37 | #4 joeseph wrote in post #11273955 They're only stuck on with doublesided tape gaskets... Back LCD cover is part number CB3-1417 "Window, TFT" Gasket is part number CB3-1416 "Tape, TFT doubleside" they're avail from Canon, or third party suppliers e.g. link Fabulous post. I can't believe Canon is charging $300 for replacing that.
I spent probably two hours searching all over the internet to try to find info on this, no luck.
| Latest registered member is zachary24 1453 guests, 137 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
