Hi folks,
I have a 1D MKIII. Last night, dim light indoor birthday party was first opportunity to use my 580EX and I must have done a number of things wrong. Could use some help. Some pics came out ok, the vast majority did not.
I figured since this was a first run, I set to P. Used ISO 100 until I thought that was not enough and moved up to ISO 320. But more had to do with the flash itself.
I bought what looked to be a very cool and logical off shoe flash mount - a Custom Brackets CB Mini-RC and a Canon OC-E3 off shoe cord. Bracket is here:
http://www.custombrackets.com …Viewnew.asp?idproduct=139![]()
I opened up the catch light panel and bounced off ceiling or right wall.
I expected this to work as E-TTL and relatively automatic until I learned more what settings I might wish to change.
First thing I noticed is that everything on the flash was blinking. I thought that might be because it was off shoe, but later read that means the wide panel is out. But it was not, just the catch light panel.
Also, many shots with my sharpest lenses were front or maybe more back focusing. The light was very low, but I missed my chosen plane of focus often.
So, obviously, I did maybe more than one thing wrong. As I said, a few keepers, but more by luck than knowledge.
So, where to start? Any combination of 1D MKIII and flash settings to start with? Preferred angle of head in this situation? Any flash setting I should not have missed?
Appreciate your help.
~Bob
But I have not played much just yet. I will.
