HI Everyone,
I need to call upon the experience of those that own and use Pelican cases for their lighting and camera gear.
I've reached the point where my needs and demands on all my gear have grown significantly and many of the soft bags I've been using won't cut it any longer for location work.
When I'm shooting on location I find I need the structure of a hard case with some additional space and I'd like that extra space to be in the form of compartments rather than velcro and zippered pockets.
So, I need 2 cases.
Case #1 is for 2 bodies with grips, each with anything as long as a 70-200mm lens attached, 2 or 3 additional lenses, filters, Speedlight, flash bracket, a set of Pocket Wizard's, CF cards, ColorChecker, spare batteries, and a small assortment of all the miscellany that you realize you need. I also want some breathing room so that if I need to open filter cases or swap a lens I have an empty space (or two) to use to make the swap or installation easier.
I know this could have been a separate post in another forum but since it is accompanied by a question about a Pelican case for lighting and the fact that most of the Pelican case users will probably also be able to make recommendations for a camera case, I thought it was ok. L)
Case #2 needs to be able to hold 3 Elinchrom RX monolights, a few reflectors, deflectors (and rods), triggers, power cords, sync cables, light meter, spare batteries and possibly a few non-Elinchrom speed rings. This case doesn't need to hold Nano's or umbrellas.
I'm sure I'm forgetting items but I think you get the idea.
I welcome any and all suggestions.
