I've only had my camera for about a month, and i'm still working everything out. All tips and criticism is very welcome.
Superguitarbitch Junior Member 29 posts Joined Nov 2010 Location: Australia More info | Nov 14, 2010 09:25 | #1 I've only had my camera for about a month, and i'm still working everything out. All tips and criticism is very welcome. To live through ones own shadow. Mute and blinded, is to really see.
Becen Member 50 posts Joined Nov 2010 More info | Nov 14, 2010 10:43 | #2 Hi, A 1000D and some lenses
Nov 14, 2010 10:45 | #3 A curves adjustment on # 1 and it will pop !! Done with Numbers. Own the X and the R
Nov 14, 2010 13:56 | #4 Becen wrote in post #11281819 Hi, I'm really new to photography too but I love your second picture. The first one would be better with light I think. What camera/lens are you using? I'm using a EOS400D with the Canon EF-S 18-55mm lens for the first picture, but for the second i'm using the EF 75-300mm. squashed wrote in post #11281833 A curves adjustment on # 1 and it will pop !! What kind of adjustment to the curves would i have to make? To live through ones own shadow. Mute and blinded, is to really see.
argyle Cream of the Crop 8,187 posts Likes: 24 Joined Apr 2007 Location: DFW, Texas More info | Don't worry about the curves adjustment just yet. Simply re-open the first image (flower) in Photoshop (or whatever program you're using) and make a levels adjustment by dragging the highlight slider to the left until it reaches the edge of the histogram where it starts to curve upwards. This will brighten the image and give it more life. After that, just play with the contrast and boost it a bit and you'll see a totally different image. Shouldn't take you any more than a minute or two. "Fat, drunk and stupid is no way to go through life, son". - Dean Wormer
Nov 14, 2010 14:21 | #6 argyle wrote in post #11282757 Don't worry about the curves adjustment just yet. Simply re-open the first image (flower) in Photoshop (or whatever program you're using) and make a levels adjustment by dragging the highlight slider to the left until it reaches the edge of the histogram where it starts to curve upwards. This will brighten the image and give it more life. After that, just play with the contrast and boost it a bit and you'll see a totally different image. Shouldn't take you any more than a minute or two. Read up on exposing to the right (ETTR)... Alright, i'll do that now To live through ones own shadow. Mute and blinded, is to really see.
Nov 14, 2010 14:44 | #7 Does that look a little better? To live through ones own shadow. Mute and blinded, is to really see.
Becen Member 50 posts Joined Nov 2010 More info | Nov 14, 2010 14:49 | #8 Wow, that is certainly better than the original A 1000D and some lenses
Nov 14, 2010 14:52 | #9 I don't like it that much, but that's just me, thank you for the comments though, i really appreciated the help you guys gave me To live through ones own shadow. Mute and blinded, is to really see.
egsr Junior Member 23 posts Joined Jul 2009 More info | Nov 15, 2010 10:43 | #10 nice job, try and push the limit for yourself a bit...see how low you can go shutter speed wise to get brighter more properly exposed images without camera shake.
| Latest registered member is Thunderstream 1858 guests, 99 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
